Cup Holder(s)?
Old Sep 9, 2013 | 10:17 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Cup Holder(s)?
Let's see some pics of how you incorporated a cup holder or two in your Third Gen!
I need some ideas as I bring this car back to life.
j
Old Sep 10, 2013 | 01:33 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Cup Holder(s)?
Something I saw here and I copied:
It holds some 20oz drinks, 16.9oz is no problem. I haven't found a fast food cup that won't fit yet, even a extra large McDonald's cup fits fine.
Old Sep 10, 2013 | 01:37 AM
Herkyone23's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7
Re: Cup Holder(s)?
Nice and clean. Great job.
Old Sep 10, 2013 | 01:47 AM
72SSboy's Avatar
Car: 1988 IROC-Z
Re: Cup Holder(s)?
Really like that! j
Old Sep 10, 2013 | 02:36 PM
85bluefirebird's Avatar
Car: 85 firebird
Engine: 2.8v6
Re: Cup Holder(s)?
Spaceboy1980 what did you use to make that cup holder
Old Sep 10, 2013 | 03:54 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Cup Holder(s)?
Here's a link. If you do a search you'll find some other options.
https://www.thirdgen.org/forums/inte...er-option.html
Old Sep 10, 2013 | 04:01 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Re: Cup Holder(s)?
I haven't figured out a solution for my bird with power windows and locks yet since they go right where people usually put the cup holders kinda sucks
Old Sep 10, 2013 | 04:19 PM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Re: Cup Holder(s)?
This isnt my car but the SLP Firehawks had cup holders
Old Sep 10, 2013 | 06:34 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Re: Cup Holder(s)?
I'd spill my drink in the door.
Old Sep 11, 2013 | 01:12 AM
Car: 1990 Camaro RS
Engine: L31
Re: Cup Holder(s)?
http://cupholdersonline.com/2-7-8-Cup-Holders_c5.htm
The bigger one is too big, won't fit. I ordered one and it was a no go. Ended up ordering the ten pack, I figured I can find other uses for them.
Old Sep 11, 2013 | 01:32 PM
Broncaro's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Re: Cup Holder(s)?
mine
Old Sep 11, 2013 | 01:34 PM
72SSboy's Avatar
Car: 1988 IROC-Z
Re: Cup Holder(s)?
I think that's the best place to put it.. really looks stock. Would be scared to cut a big hole in the upper console though.
Old Sep 13, 2013 | 01:21 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: Cup Holder(s)?
Kinda off topic but i really need to do this. Every time me and my wife get fast food in my car i have to hear about how dumb my car is for not having cup holders. I tell her its built for speed not comfort lol.
Old Sep 22, 2013 | 05:31 PM
art91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 350 5.7 liter
Re: Cup Holder(s)?
Nice and clean
Old Sep 29, 2013 | 04:06 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Re: Cup Holder(s)?
If you can get a hold of an old console with the clock in it, the hole for the clock would be perfect for a cup holder. I think its in the same spot as the one pictured.
Old Sep 29, 2013 | 04:40 AM
Car: 1990 Camaro RS
Engine: L31
Re: Cup Holder(s)?
How is the clock centered Mike? If you look closely you'll see I centered the cup holder to the hatch pop switch. The cup holder is actually off center to the right in the actual panel it is in. I think if I had actually centered it that it would look off center due to the location of the switches.
Old Sep 29, 2013 | 04:43 AM
((Mike))'s Avatar
Engine: 383 Stroker
Re: Cup Holder(s)?
Good question. I think its right in the middle. Somewhere on this site I saw some photos of the console with the clock still in it. Your probably right. I never noticed that the switches are off center. Good eye.
Old Sep 29, 2013 | 04:48 AM
((Mike))'s Avatar
Engine: 383 Stroker
Re: Cup Holder(s)?
Here is a photo with the clock i found on here.
Old Sep 29, 2013 | 06:09 AM
Car: 1990 Camaro RS
Engine: L31
Re: Cup Holder(s)?
It's hard to tell from that picture, everything looks centered on it including the switches. I wonder if they off set the switches in the later years, mine is a 1990 for reference.
Old Sep 29, 2013 | 06:15 AM
((Mike))'s Avatar
Engine: 383 Stroker
Re: Cup Holder(s)?
Mine is an 87. But I don't think the clock was offered as an option after 84 or 85. Im guessing but I don't remember ever seeing one in an IROC, Just in the Z28s from the first three years or so.
Old Sep 29, 2013 | 09:51 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Cup Holder(s)?
The center console of the Camaro is made of two pieces. For a cupholder installation you don't need to remove anything because under the plate (behind the window switches) there is empty space that will accommodate something hanging down like a cup holder or clock assembly. However, if you are installing a clock, you'll need to remove the top portion of the console to access holes to screw the clock into.
To do it clean, invest in a hole cutter bit for a drill. They are available at any Lowes or Home Depot or, what I did, was find a used tool dealership where I paid 7 bucks. Trace the bottom first then score it with an xacto blade so the bit will have a guideline to prevent slight kickback and a subsequent scratch to repair (this happened to me).
Old Sep 29, 2013 | 09:55 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Cup Holder(s)?
There is a company who incorporates the cup holder with a new armrest pad. A search should find them.
Some guys get a $5.00 holder and attach to the side of the console.
OR...buy a 4th gen centre console (with built-in cupholder) and swap.
Old Oct 6, 2013 | 05:41 PM
SandmanSS's Avatar
Car: 87 Iroc Z28-2010 SS/RS
Engine: 350/427
Transmission: Manualx2
Re: Cup Holder(s)?
I like the accessory outlet; that's a perfect low profile spot.
Old Oct 6, 2013 | 08:39 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: Cup Holder(s)?
This was neat ... somebody elses idea on here ... I kept a picture of it.
Fold down cup holder, nice.
Old Oct 6, 2013 | 09:20 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Cup Holder(s)?
Old Oct 6, 2013 | 09:23 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: Cup Holder(s)?
spaz model
Old Oct 7, 2013 | 02:29 PM
Richboll's Avatar
Engine: 305 TBI
Re: Cup Holder(s)?
I have the fold down cup holders. They work really well. The only problem is that in cool weather when using the heater, the heat blows right on my cold soda. It'd be great if I were a coffee drinker!
Fanatic1074
Oct 3, 2022 05:57 AM
75bike
Sep 20, 2015 09:37 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
gta892000
Sep 16, 2015 12:37 AM
