High beam indicator
Old Oct 19, 2013 | 12:25 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
High beam indicator
I finally got around to putting blinker and high beam indicators on my autometer gauge panel and the high beam indicator comes on with the running lights and low beams. When I hit the high beams the indicator gets brighter and when I turn the low beams off it stays on but is dimmer. Any ideas? I took the wires from the stock harness and wired them into the indicator bulbs the grounded the other side of the bulbs.
Old Oct 20, 2013 | 09:40 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Re: High beam indicator
A bad ground on a low beam headlight is a possible cause
Old Oct 21, 2013 | 05:44 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Does sound like a bad ground,
Old Oct 21, 2013 | 10:40 AM
mikeirocz1's Avatar
A bad ground for the indicator light or headlights? I have hid headlights with the high beam and low beam on one bulb. It has its own relay harness.
Old Oct 21, 2013 | 04:03 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Oh, you have HIDs.. This adds a new twist to the topic, and another possible solution.
If you take a 6054 from a TA and throw it in an IROC it wont light properly, conversely the 4656 from the IROC wont work correctly in the TA.
The 6054 pinout is the same as the H4, so an adapter is not needed. But on a Camaro it is needed.
Depending on how universal of a wiring kit was included, this could be the problem. Have you contacted the manufacturer of the retrofit?
Old Oct 21, 2013 | 09:05 PM
mikeirocz1's Avatar
Retrofit? I have a bi xenon hid kit with a relay harness. The car has no computer, if that matters. The hid kit is for the stock H4 bulb setup. I bought some 12v indicator lights from radio shack and wired them into the factory high beam and blinker indicator wires. I guess I'm not real clear on what your saying, sorry.
Old Oct 21, 2013 | 09:44 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
The layout of the wires within the stock 4656 connector is different than an H4 connector.
3rd Gen H4 Conversion Question
So by adding a kit based on an H4 socket, you are inheriting the difference in wiring; and thus the most likely cause.
Old Oct 22, 2013 | 08:06 AM
mikeirocz1's Avatar
Oh yeah, I did that when I hooked them up. The high beams wouldn't work so I called the company and they told me to swap the wires. So the high beams work but I have the high beam indicator staying on.
Old Oct 22, 2013 | 03:19 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
I wish I could be of more help but I am not an HID retrofit pro. Maybe another board member could chime in or you could contact one of them as there are a few threads here about it.
.. or you could always try the manufacturer
Old Oct 23, 2013 | 07:44 AM
mikeirocz1's Avatar
My stock headlight harness wasnt making a good connection with the hid kit. I cut out the stock plug and replaced it and it seems to be working fine.
Old Oct 15, 2015 | 08:43 PM
NWFreerider's Avatar
Car: 1991 Z28
Axle/Gears: 3.73/Tru Trac
Bringing up an old thread but I have the same problem since I installed LED headlights in my '91 Camaro. I did the wire swap as shown above so the high and low beams work correctly with the H4 harnesses and my high beam indicator glows as soon as I turn on the parking lights. Also, the individual LED cells (15 per light) glow on the high beams when they aren't on. Is this due to the improper grounding? Any possible fix?
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
