Overhead console button sticking
Old Nov 23, 2013 | 10:14 PM
xcorvettekid06x's Avatar
Car: 1991 Camaro RS
I just put an overhead console in my car. Installation went good, but the map light button is sticking. Does anybody know how I can fix this? I'll post pix of the console soon.
Old Nov 24, 2013 | 07:41 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Overhead console button sticking
wd40?
Old Nov 26, 2013 | 12:39 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
I'm guessing that your car did not have one from the factory.
I installed one in my car and that button sticks if you don't have the headliner cut back far enough to clear the back of the button.
I'm not sure why that would cause this but it does.
Old Nov 26, 2013 | 01:21 PM
Car: 1991 Camaro RS
It's deff not the headliner. It sticks when it's not even installed. I read that in the installation article. I wish it was that though lol. Could I spray wd40 on electronics?
Old Nov 26, 2013 | 10:21 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Mine did that too when I reinstalled it. It's just too tight in that respective corner. Grab the edge of it with one hand and gently pull it down a tiny bit. With the other finger, click the button. If it works correctly now, it was misaligned slightly/pressed too close against the fabric. Loosen the screw a bit, realign and try again. As with most things in the interior, go slow and especially; be gentle!
Old Dec 1, 2013 | 12:26 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
mine did it to replaced switch and spring works fine now
Old Dec 1, 2013 | 01:52 PM
Car: 1991 Camaro RS
How do you do that?
Old Dec 1, 2013 | 05:22 PM
Sam L.'s Avatar
Take apart the backside of console take out button got spring and button at RadioShack and look identical hope this helps
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
