Painting interior panels
Car: 89' Trans Am KARR Rep.
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 3.27 Posi Disk
I've got a problem, I want to paint my interior panels Lt Sand Gray, but the problem is that Lt Sand Gray was only in 83-84 cars so finding good panels in the yard is next to impossable, so I figured I'd just dye mine instead, HOWEVER........ there seams to be a serious lack of 80's dye's available, at least the Lt Sand Gray color anyhow.... I CAN however get it mixed as paint, but from that I've seen, just paint the panels they'll peel n flake off, and since I REALLY have no intention of removing my interior to repaint it all.... What can I use to permanently bond the paint to the plastic or where in the world can I get Lt Sand Gray Interior Dye's??? Classic Industries nor YearOne have it listed, I tried searches for that dye on the internet as well as sources of dye's hoping that I'd get lucky. All failed, so please someone help me...
Thanks,
Joe
Thanks,
Joe
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Painting interior panels
Are you looking for a vinyl spray paint ?
http://www.tcpglobal.com/autobodydepot/aerovinyl.aspx
Engine: 305 TBI
Thanks. I'm looking for whatever i can use on the plastic, i'll need some fabric dye too but i more need plastics done. I'll check those samples on that site n see if i can find something.
Joe
Joe
Engine: Lb9
Transmission: M20
I have used vht and duplacolor in the past they work great. The key is prep with scotchbrite and wipe down with rubbing alcohol
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Professional paint guy who is a vendor at my dealer told me to clean really well and use an adhesion promoter before painting and there will be no problem peeling. I had him do a few pieces for me over a year ago and they are still perfect.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
i used to use SEM at the shop, key is prep work, TSP, Dishsap and some denatured alcohol all do wonders, hit it with some adhesion promotor and then use your dye. ive also had luck with regular spray paint but after awhile even if it doesnt peel it gets cruddy from the oils in your body.
Car: 1983 Z28
Engine: 385 Fastburn
SEM, duplicolor, or what I personally used was Krylon. All are made with an adhesion promotor built in (though you can use some for extra measure). As long as you allow for the proper drying time they hold up well and haven't chipped so far.
Engine: 305 TBI
Thanks everyone.
Actually on that line i ment respraying it again in the future after the interior is all finished. The interior of my car is actually partally torn appart now n needs redone.
Joe
Joe
AkDrifted
Aug 17, 2015 07:45 PM
