Need a New Driver's Seat
Old Mar 18, 2014 | 11:36 AM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Hi, I have a 1989 Camaro with a worn down driver's seat. I was looking to replace the cloth seat with something a little more comfortable for daily driving because right now I am suffering back pain from years of driving my car with racing suspension and a worn seat. Is there a cheap set of vinyl seats that I can buy off ebay that would bolt right in on the existing platform? Is there a way I can upgrade to leather iroc z seats? I need to buy a new seat because I can't take the back pain after driving any longer. Any help will be highly appreciated!
Old Mar 18, 2014 | 07:09 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Need a New Driver's Seat
all 1982-2002 camaro/firebird seats will bolt right in.
Old Mar 18, 2014 | 10:17 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Sounds like the foam is just worn out. If the seat covers are in good shape just install new foam and you should be in good shape. Remember that even fourth gen seats are at least 12 years old. Unless you find seats out of a very low mileage car, any seat you find will be worn out to some degree.
Old Mar 18, 2014 | 10:43 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
Me myself I see a lot of like $139 no name plane Jane black vinyl racing universal seats on eBay but I don't know if they would fit. I need to front seats as well. My back seats are not even worn in no dirt nothing.
Old Mar 18, 2014 | 11:03 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
FYI, the foam from a passenger side is the same as the drivers side foam. It's easy to find passenger foam in good condition
Old Mar 19, 2014 | 04:37 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Yep, either that or a local foam/upholstery shop should have what you need.
Old Mar 19, 2014 | 09:25 AM
I was looking at those and wondered if they are more comfortable than the stock cloth seats. Also, I saw that I could buy new seat foam for $150, but I don't know how good it would be. I'm running stiff koni's and sportlines, so I feel every bump.
Old Mar 19, 2014 | 01:33 PM
Scorpner's Avatar
Engine: V6, V8
A local foam/upholstery shop should be able to determine the type and density of the foam, and may even be able to offer suggestions on what to use (Edit: ...if you're looking to improve anything).
IMO, the Thirdgen seats are more comfortable but provide less lateral support.
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
