help with gas gauge...
Old May 21, 2014 | 07:22 AM
Laugh-Master!'s Avatar
Car: 84 camaro berlinetta
Low fuel light was on but the fuel gauge says full... I think my gauge is shorting out... Any suggestions on how to fix it?
Old May 21, 2014 | 12:58 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: help with gas gauge...
im not an expert on the berlinetta gauges/senders in any way, but i would trace the gauge wire back to the tank, make sure its not showing bare wire anywhere that could ground out, i also have never had a thirdgen with a low fuel light, so im not sure if the sensor for that is on the sending unit or seperate, if it is separate its possible the sender on the float for the gauge is bad and reading full all the time
dlinger's Avatar
Car: 1984 Z28 HO
http://www.justanswer.com/chevy/5nwr...k-cluster.html
We had a bad sending unit in the tank of our 84.
Old May 21, 2014 | 02:00 PM
Thank you both for the input, I'll check things out soon
Old May 21, 2014 | 07:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Most likely a bad fuel tank sending unit or a short if it is pegged full. The sending units go bad over time unfortunately. If it's the sending unit don't even bother getting one used as they break very easily, new with a warranty.
Old May 22, 2014 | 06:56 AM
Alright thanks. The guy I bought it from said the guy before him put in a new tank and the gauge never worked for him either
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
