HVAC stuck on defrost after T-5 swap
Old Jun 11, 2014 | 03:28 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
So I swapped my auto out for a T-5 in September, and ever since the swap, my heat has been stuck on defrost. The car is originally an AC car (AC compressor has been removed but controls are original) and I read on here my issue is that I lost the vacuum source to the HVAC controls, which is very possible I may have damaged a vacuum line during the swap, as I was laying on top of the motor trying to reach the upper bellhousing bolt.
Where does the HVAC vacuum supply go thru the firewall?
My only other thought was that some hardware may have gotten dropped into the defrost vent and it may have become lodged in the selector door. Is this even possible? Could a bolt that fell in the defrost vent lodge itself in the door, I'm not sure what kind of path the air takes in the dash.
Any input would be appreciated. I want all my vents to work again
Old Jun 11, 2014 | 06:42 PM
billyhoss's Avatar
Re: HVAC stuck on defrost after T-5 swap
on my 91 z28 it comes in with the wire cluster on the right hand side of the ac and heater fan in the engine bay, almost right at the top
Old Jun 11, 2014 | 09:35 PM
Yep, the vacuum line was disconnected, all fixed now. I feel so silly.
Old Oct 28, 2014 | 09:18 AM
Garges24's Avatar
Car: 86 Z28 Camaro
Engine: Sbc 434
Axle/Gears: Currie 9" 4.11's
I have the same problem but I can't figure out what happened. I had the old a/c heater box and everything worked fine. I put in an a/c delete box and now all I get is defrost. Where does the vacuum line tie into the heater box?
Old Nov 7, 2014 | 12:42 PM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
I must have bumped that hose on my '88 Formula, I am having the same problem, (airflow defaulted to defrost only) I can't find the line though. any chance of posting a pic?
Old Nov 7, 2014 | 02:17 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
2 hard lines come out of harness by firewall and heater motor. One goes to the Heater control valve, the other goes to vacuum source.
Old Nov 7, 2014 | 02:45 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
HVAC stuck on defrost after T-5 swap-img-20140717-00925-1 Hard line at firewall to Check Valve and Plenum Vac Source
HVAC stuck on defrost after T-5 swap-img-20140717-00928-4 Heater control Valve, 2nd Hard Line
HVAC stuck on defrost after T-5 swap-img-20140717-00932.jpg Another View of Check Valve
Hope this helps
Bob
Old Nov 7, 2014 | 11:39 PM
Garges24's Avatar
Car: 86 Z28 Camaro
Engine: Sbc 434
I dont remember having the vacuum line with the check valve. Mine was a carb 305 originally…could that be a difference? I literally hooked up the ac delete box the same exact way as the original ac box was. This is really driving me nuts!
Old Nov 8, 2014 | 08:05 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The pre '90 ac delete boxes are not vac controlled, all done with cables. Did you replace the whole heater core/selector box or just the blower on the firewall?
Old Nov 8, 2014 | 02:49 PM
Garges24's Avatar
Car: 86 Z28 Camaro
Engine: Sbc 434
I bought the ac delete box from Hawks. It had a blower motor in it, all I did was put my resistor in it and went.
Old Nov 10, 2014 | 09:48 AM
stealtht/a's Avatar
You only changed the blower housing. You still have the vacuum controlled vent /heater core box under the dash. You have a vacuum line coming through the firewall that feeds vacuum to the control box under the dash. Maybe the PO cut it off.
Old Nov 10, 2014 | 10:04 AM
Garges24's Avatar
Car: 86 Z28 Camaro
Engine: Sbc 434
Mine originally didn't have vacuum lines run to the ac heater box. I can change the air from hot to cold but when I try to change where I want the air it does nothing. I checked the cables under the dash and everything seems to be hooked up right. I'm running out of patience with this damn car!
Jorlain
Aug 24, 2022 05:11 PM
777Shock777
Oct 29, 2015 04:30 PM
Cameeeero
Sep 18, 2015 04:00 PM
Cacike
Aug 27, 2015 05:10 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
