Replacing auto shift knob with...?
Old Jul 2, 2014 | 06:25 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Replacing auto shift **** with...?
Does anyone know if the auto shift ***** from the C4 Vettes are compatible with our cars? I would assume the 700R4 ones would fit, but would like to know from anyone who has done the swap.
Old Jul 2, 2014 | 08:49 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Re: Replacing auto shift **** with...?
Really? K-n-o-b-s is censored?
Edit: Sometimes it's censored, sometimes not. Weird.
Anyway, are shift ***** from vette's a direct fit swap? The **** on my '92 is pretty beat up and sun-dried, so thinking about getting a shift **** from a C4.
Old Jul 3, 2014 | 02:45 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I seen some Sick Speed ***** for automatics on ebay. I don't care for their designs but their ***** come with an adapter that eliminates the button. Instead of a button, you have to push down on the whole ****. Kind of like the old manual transmission VW bugs when searching for reverse.
If you want to keep the stock look, the OEM ***** are still available.
Old Jul 3, 2014 | 07:05 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
yes, you can also use the 4th gen camaro **** for an OEM look, this is the **** that is still available, its only slightly different from the 3rd gen **** as it extends down the shaft about an inch further than the original, i like the look so i put one in mine
Old Jul 3, 2014 | 03:52 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
You can also use the Firebird 'T-handle' style ****. Put one in my son's '87 Camaro
Old Jul 3, 2014 | 04:54 PM
cdoyle's Avatar
Could you post a pic? Would like to see how it looks compared to the 3rd gen type.
Old Jul 12, 2014 | 03:15 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Ok, got a C4 shift k-n-o-b in the mail yesterday, and this particular one will not fit without modifications. The inside diameter of the C4 k-n-o-b is larger than the F-body one. Also shift **** buttons are not interchangeable from C4 to F-body. Not sure what year C4 exactly it is from, but won't work without shimming it somehow. Oh well, I'm out maybe $13.
Old Jul 12, 2014 | 07:12 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
here is mine with a 4th gen shift ****, granted it is in a 4th gen console as well. Bolts right up.
Old Jul 12, 2014 | 07:29 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
I believe all of the Camaro shift k-n-o-b-s are the same from 88-02, they even used the same ones in Cavaliers and Berettas, but the Camaro ones were probably the only ones leather wrapped. I assumed an auto shift k-n-o-b from a 1992 or 1993 Vette would fit since it's the exact same transmission in the F-body cars (aside from the servo), but it appears the Vette k-n-o-b I got in the mail won't fit.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Leggman1
Aug 6, 2015 04:15 AM
