gauge cluster out of v6 will it work in v8
Car: 91 rs camaro convertible TBI 5.0
Engine: 5.0 Lt.
Transmission: auto
Axle/Gears: ?
I have a 91 camaro rs v8 will the gauge cluster out of a 91 v6 work I know it will fit but will it work ?
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: gauge cluster out of v6 will it work in v8
the tachometer will be off.
Engine: 5.0 Lt.
Transmission: auto
Axle/Gears: ?
most of the tachs are off anyway , there is a guy that will send the right chip that has been repaired that will get your tach to read correct for the V8 in the V6 cluster for cheap. I think the only other difference is the 60vs80 psi oil gauge and you can put in the V6 sender under the hood or just not worry about the reading being a tad off.
Engine: 5.0 Lt.
Transmission: auto
Axle/Gears: ?
Cool do you have the guys contact info, so that it can be corrected .
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
There is a ton of information here if you search for it. I just posted a few links in another thread so I'll give you the link to that thread. In there is another thread dedicated to the accuracy of the 91-91 tachs, plus how to dial a V6 one for a V8. If your old tach still works you could transfer the tach from your old cluster to your new one. In fact, that's what I would do.
It's the holiday weekend which may be why you're not getting much of a response.
https://www.thirdgen.org/forums/elec...oeter-fix.html
Links from the other thread:
https://www.thirdgen.org/forums/elec...meter-fix.html
http://www.fieros.de/en/articles/tach.html
https://www.thirdgen.org/forums/elec...ml#post3004390
There is also a guy on here that fixes them but I don't have the time to search, but if you do you should be able to locate one of his threads.
Engine: V6, V8
Elephantismo
Feb 13, 2019 12:51 AM
