Custom Guage ideas in Trans Am
Old Oct 26, 2014 | 03:13 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
OK, I have search around, and pretty much read both threads on show me your gauges and custom interior but didn't find what I am looking for, at least I don't think. so I am turning to you guys for help.
I have never liked the 4 big ovals in the Trans Am pod, and I was browsing eBay and found a bezel with only 2 ovals, but it has a bunch of little ovals cut out.
So, when I place it over my gauges you can see parts of them. Well, easy and cheap fix, I got some fabrics and taped it to the gauges.
And now the after picture.
Old Oct 26, 2014 | 03:15 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Re: Custom Guage ideas in Trans Am
Now, I went and purchased small gauges to replace all the stuff that is covered up. Fuel level, Oil pressure, Battery Voltage, Water Temp, and Air PSI.
Old Oct 26, 2014 | 03:18 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Yes, I know one is chrome, I am fixing that. I also, may purchase a Trans temp or some other gauge (suggestions?) to make it an even six.
Now, onto my other issue at hand.. Where to mount the rest?
2 or 3 on the pillar, then 2 or 3 where else? I don't want to drill into the dash pad, but I have seen 2,3,4 gauge pods that I may be able Velcro up their, but then what about running the wires? If I don't get any viable suggestion I may bite bullet and brill through the dash pad...
Old Oct 26, 2014 | 03:21 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Something like this is the only thing I can think of.. but like I said scared of hacking up the dash pad:
Old Oct 26, 2014 | 08:31 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I'd find a way to use the empty space where the holes in the dash are. Seems kind of silly to have all those holes there that serve zero function.
Old Oct 26, 2014 | 08:37 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
I am open to that, but how would I do it? The gauges are 2 inches deep, no mounting room without drilling into the gauge stock cluster.
1. Scared I could break it or ruin it completely from working on the half I need, MPH/RPM
2. I would want to easily return stock maybe down road?
Old Oct 26, 2014 | 10:17 PM
Night rider327's Avatar
Car: 1988 Camaro
Try looking for a junkyard, CL cheap gauge cluster.. On the cheap cluster, cut the clear plastic lens right past the tach.. Remove your other gauges or warning lights or what ever from JY cluster.
Grind out some of the holes in your bezel and push your aftermarket gauges through untill the gauge's lip/ring touches.
Old Oct 28, 2014 | 07:40 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Call me crazy, but I want to mount a 7-10" LCD in that area actually.. I was just thinking they make LCD's that are 1/2" - 1" thick that I could easily mount there. A lot easier than a 2.5" inch deep gauge. Plus I wouldn't have to hack up the gauge cluster behind it . I was thinking about doing a carputer in one input and full time back-up cam in the other input on monitor. I have a super small HP slim tower, almost smallest they make.. was thinking of doing rear-seat delete anyway so I can mount it somewhere back there, and mounting the back-up cam most likely into one of the hot's from my system to always run.
I have always been looking for a good place to mount a 2nd screen other than my double din and I think I just found the spot. At least in Camaro's they have a little room between the heater controls and vents.. in Trans am there is no room.
Let me see if I can crudely mock something up.
Old Oct 28, 2014 | 07:51 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Old Oct 28, 2014 | 07:52 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Very crude, just using MS-Paint. You can get the idea though.
Which leaves me again, where to put the gauges?
Old Oct 28, 2014 | 08:23 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Found this monitor it's thin, only 60$.
Dimensions: 7.6 x 5.24 x .98 in
http://www.ebay.com/itm/Pyle-7in-LCD-Back-Up-Camera-System-/390956297102?pt=US_Rear_View_Monitors_Cams_Kits&hash=item5b06cfab8e&vxp=mtr
Old Oct 28, 2014 | 08:25 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
This is the computer I have, it's super thin:
Dimensions: 2.6 x 9.9 x 10 in
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Fast355
Dec 2, 2016 06:33 PM
355sbcTPI
Aug 19, 2015 04:38 PM
kah992
Aug 19, 2015 02:55 PM
