Rear Defrost?
Old Dec 20, 2014 | 10:38 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
Rear Defrost?
Has anyone ever put a defrost hatch into a car that didn't originally have it? I have a parts car that has a defrost hatch that I would like to put in my '87 TA.
Old Jan 12, 2015 | 03:39 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Rear Defrost?
You'll need the dash switch of course, and there's also a relay you'll need that bolts to the inside of the passenger side of the dash just behind the map pocket. Not sure if non-rear defrost cars had the electrical leads for rear defrost built into the standard or not, but all models should have the grounding points built into the rear hatch struts.
Old Jan 15, 2015 | 02:46 PM
blktransam's Avatar
Re: Rear Defrost?
Do you think the '84 TA would have the relay I would need?
I'm going to need to find a matching defrost button for my 87'.....
Old Jan 15, 2015 | 03:46 PM
navy02ws6's Avatar
Re: Rear Defrost?
Dunno about an 84...IIRC, the one I got came out of an 85, and plugged right into my 91's harness and bolted up with no problems.
Old Jan 16, 2015 | 10:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear Defrost?
Shows Everything,.... 85+ set-up.
https://www.thirdgen.org/forums/elec...defroster.html
Old Jan 16, 2015 | 10:24 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Rear Defrost?
The wiring on mine was pretty easy to install. Still dont have the hatch though. But the switch works. lol
Old Jan 18, 2015 | 01:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Rear Defrost?
near the hatch, drivers side has power coming up from the dash, passenger side is grounded to chassis.
Ozz1967's Avatar
Car: 1984 Trans Am
Re: Rear Defrost?
I also need one of those under-dash rear-defrost timer relays but I can only find them used.
Old Jan 19, 2015 | 01:02 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: Rear Defrost?
The timer is built into my switch.
Old Jan 19, 2015 | 01:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: Rear Defrost?
Mine is as well, I just can't find a new one anywhere. All I can find are used on EBay.
Old Jan 19, 2015 | 06:33 PM
blktransam's Avatar
Re: Rear Defrost?
I'm not sure if I even want to deal with all this wiring crap or not....
I haven't tested the hatch yet either....
hectre13
Dec 11, 2023 08:14 AM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
