Anyone running no console with a manual?
Car: 1983 Z28
Engine: 385 Fastburn
So, I have always really liked older cars where the console is non-existant and you just have the shifter boot and classis bent shifter on the tunnel. I've seen MW's automatic with the console delete, looked pretty good, but i'm looking for any clean examples of manuals that have gone that way.
Of course, I know I need to do a manual swap first, but that's a couple years down the road. Just looking for ideas.
thanks!
thanks!
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Re: Anyone running no console with a manual?
I've seen it done, in some older cars, let me see if I can dig up some pics.
Car: '87 Trans Am
Engine: 5.0L-V8
This may give you some idea's:
1974 Firebird:
Third Gen Camaro:
1985 Mustang:
85Mustanginterior.jpg?t=1231688232
1974 Firebird:
Third Gen Camaro:
1985 Mustang:
Car: '87 Trans Am
Engine: 5.0L-V8
I think the cleanest and easiest would be the top one in the older Trans Am. You may have to buy new carpet, depending on how big the hole is cut for your current center console. Either way, looks like you can just make a metal ring that screw into the floor pan to hold the boot in place. You may even be able to make it work with the auto and be able to convert for the manual later..
Car: 1983 Z28
Awesome examples, thanks! Yeah, I was thinking that. Might look into that when the weather warms up!
Car: '87 Trans Am
Engine: 5.0L-V8
I like it.. but then again I don't, if that makes sense lol.
I can respect it, if done cleanly, but I don't think it's a route would go personally. Although I do think a B&M Megashifter (that's what I have) would look awesome with console delete. I've seen them put into old Chevy K's and S10's, looks good.
Car: 1983 Z28
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
The first thing you would need to do is figure out where to put the heater controls & radio. After that you would be fine - but I don't think it will have the same clean look the older cars did.
Here are some pics of the 69 Red/Red RA III/4spd GTO I did a few years ago. That was a fun car - I should have kept it.
Axle/Gears: 3.45, 3.27, 3.27
Car: 1983 Z28
Beautiful car!
Yup, the firebird pod is what I was thinking too.
1992 Trans Am
May 10, 2023 07:19 PM
