how rare is the non ac dash for camaro's
Car: 85 iroc z
Engine: air for now
Transmission: none
I ask because I've been looking for one for over 4 months now. Was this a rare option I'm aware most of these cars came with ac. But did not think it would be this hard to find one.
Transmission: 5-Speed Manual
Re: how rare is the non ac dash for camaro's
A/C Was An Option, A/C Was Never Standard Equipment On These Cars,It Was Either An Individual Option Or In A Preferred Equipmemt Group. The Only Exception Being The 1987 LT
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Even on the 1le cars that didnt have a/c they still had heat so the dash vents and control panel would still be there. The dashes would be identical with the exception of the control panel itself....
my 84 before I swapped out the dash, was a no A/C car. It actually only had the 2 vents above the radio.
Where the side vents were suppose to be, they had indents for where the vents should have been. but no actual vents.
Car: 85 iroc z
Engine: air for now
Transmission: none
Transmission: A4
Huh, learn somthing new everyday.
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
There's one of these dashboards in a Camaro at a local yard here. Threw me for a loop first time I saw it.
Car: 85 iroc z
Engine: air for now
Transmission: none
That's why I want to get a non cracked one. and replace the old one it's not often seen. I've had 4 of these cars and my friends have had several. And I did not know these could came with a dash like this until I got this car.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Are they not just block off plates like on the firebird?
On firebirds they are screwed on to the backside like the vents are, no visible fasteners on front side.
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Yes, aren't those just block off plates over the vent holes? The rest of the dash is the same.
Car: 89 Iroc Convertible
Camaros did not use block off plates like the firebird.The vent holes are actually filled in.If you wanted to add vents you would need to cut out the holes
Ok, so it is the same dash they just cut out the holes for the ac cars. So if you convert to non ac you just have to glue a plate in there.
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Are these non A/C cars or just dashboards? If these are legitimate A/C delete cars what kind of glass do you have, is it tinted? Do your windshields have bluish band at the very top?
Car: 91 Z28
Everything is different. Different ducting, different controls. Look under the steering wheel in the pics you can see the pull cable controls for the fresh air vents. The 91-92 camaros had all the vents and vacuum operated fresh air vents on the non A/C cars.
Axle/Gears: 10 Bolt 2.73 Open
The older models had these left/right air vent under the steering column that pulled in outside air. The controls were all cable driven, no vacume. I think I think I still have that old heater box with the controls somewhere.
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I bought an 86 z28 and am parting it out. it came with the a/c delete package. im going to pull it and keep it all together . if anyone in interested in it let me know
Car: 1989 Camaro RS
Engine: LB8 / 2.8l V6
Is the 4th gen steering wheel a direct fit for a 3rd gen column? Or would I need a whole column?
The_Phoenix
Feb 4, 2016 07:10 AM
NufNuffZ28
Aug 14, 2015 09:12 AM
Vintageracer
Aug 11, 2015 08:13 PM
