what is this piece called?
Old Mar 7, 2015 | 10:20 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Axle/Gears: 3:73 (open diff or broken)
I've been doing the interior on my car and while installing the headline I found that the piece that bolts over the t top latch hole in the front that the a pillar trim screw to is broken.
I've searched all over for a replacement but I can't find it http://tinypic.com/r/riygp2/8
Old Mar 7, 2015 | 11:23 PM
Johngypsy's Avatar
Car: 1990 Iroc z
Engine: 5.7 liter Tune port 383 stroker
Transmission: 5-speed
Axle/Gears: 3.45
Re: what is this piece called?
You need to retake a new pict, and zoom back away from it, your pict looks like a exhaust sys to me, repost and we can help you if we can see the pict much better
Old Mar 7, 2015 | 11:30 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
ok I will tomorrow. I thought it was a pretty good description of where it is though.its on the windshield where the t top latches . its the plastic piece that the a pillar trim screws to.
The close up is to show the actual part (the black plastic piece)but I will take a different picture tomorrow
Old Mar 7, 2015 | 11:37 PM
Johngypsy's Avatar
Car: 1990 Iroc z
Axle/Gears: 3.45
Ok, a better description for me anyways.
There are a few bolts that go there,
1) from 1985-1988 the Camaro came with the upper Counsole the one with the flashlight,
So there was screws tbere to hold the Counsole into place, some cars and mainly 80% did not have them installed from the factory, but General Motors did leave the bolts there as these tops was made one way, so I'm saying that, they should be for the Counsole, and other one is for the ground, for the mirror,
If you look farther back there would be an additional open bolts not used,
I'll try and post u a pict of what I mean, if I can because I am on my iPhone
John
Old Mar 7, 2015 | 11:51 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Yea were way off on location. I'll take a pic real quick to show location. Just a sec.
Old Mar 7, 2015 | 11:58 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Old Mar 8, 2015 | 12:10 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Another bad pic!!!
Old Mar 8, 2015 | 12:29 AM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
You wanted the location. That pic shows the location. The outside top corner of the windshield where the t top latch hole is. Zoom in to the other pic and it shows the actual plastic part where the a pillar trim screws to that is broken. I guess I can take some high def pics tomorrow bit I feel like Its pretty descriptive. I guess day light will help out alot
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
its where the t top rod goes when you close the lever on the t top.. dont know wht its called. you need new one?
Old Mar 8, 2015 | 12:36 AM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Just the plastic piece that goes over the hole where the t top rod latches. That plastic piece has the screw hole for the a pillar trim and mine is broken off
Old Mar 8, 2015 | 12:44 AM
mantaguy's Avatar
Engine: 5.0 EFI
You mean this ??It's a Windshield molding,Do you need one?I have one.
Old Mar 8, 2015 | 01:00 AM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Not the molding. Un screw the screw in the pic and pull the trim piece down. There will be a plastic mounting point for the molding itself. That's the piece I need
Old Mar 8, 2015 | 12:45 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
there is one on ebay now if you need it. here is the link.
http://www.ebay.com/itm/1990-CAMARO-REAR-L-H-DRIVER-SIDE-T-TOP-ROD-PIN-MOUNTING-BRACKETS-OEM-/201302322584?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ede8dad98&vxp=mtr
Old Mar 8, 2015 | 12:46 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
here is one on ebay i found if you need one.
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Thanks!
Old Mar 8, 2015 | 12:49 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
Dang! I need the passenger but I know what to call it now.
Old Mar 8, 2015 | 05:34 PM
chope1984's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: 700r
thanks for the help I was able to purchase the part I need. I don't know how in the hell you were able to track it down that fast because I searched and searched for days! thank you very much
Old Mar 9, 2015 | 01:16 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
No prob! good luck!
abray1
Sep 14, 2015 08:18 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
ericjon262
Sep 11, 2015 06:07 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
