Speedometer removal
Old May 31, 2015 | 12:15 PM
Humphrey Lees's Avatar
Car: '82 Camaro
Engine: 305ci (SUJ) not crossfire
Transmission: TH350
Axle/Gears: Stock
Speedometer removal
I really need to take out the speedometer in order to repair a broken spindle.
The steering wheel is off and all the screws are out of the white cluster moulding but that is about as far as I can go.
Any tips?
Old May 31, 2015 | 01:40 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Speedometer removal
Update your profile. Year, make, model vehicle plus specifics will help us make an educated guess.
Old May 31, 2015 | 02:25 PM
Car: '82 Camaro
Transmission: TH350
Axle/Gears: Stock
It is an 83 Camaro Z28
Old May 31, 2015 | 04:47 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
you have to remove the entire cluster to get the speedo out of the housing,
after all screws are removed, and the two speed nuts down in the dummy light area, you must lay under the dash and release the speedo cable with a long screwdriver(or something similar)
that will allow the entire cluster to be removed, after that you remove the screws on the back side of the speedo to get it out of the cluster
Old May 31, 2015 | 05:17 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I've found that it helps to drop the steering column to reach the back side of the speedometer and the cable.
Old Jun 1, 2015 | 05:53 AM
Car: '82 Camaro
Transmission: TH350
Axle/Gears: Stock
Thank you for all your help. I managed to get to the clip behind the speedo and it all came out.
Sadly the speedo itself has been cannibalised and the two driving spindles for the miles counters are missing. It is the twin speed version, so I would be interested in any parts.
The needle is broken off but that should fix with some glue.
Old Jun 1, 2015 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider advertising in our site's classifieds for one that's complete. Or buying a later mechanical version: 85, 110, or 140.
JamesC
Old Jun 1, 2015 | 01:29 PM
Car: '82 Camaro
Transmission: TH350
Axle/Gears: Stock
I just found an 85 locally for €80 that is a complete unit with all the gauges and glass.
fyo that is about the same in dollars without the shipping.
Love this site. Keep up the good work guys.
Old Jun 1, 2015 | 03:14 PM
JamesC's Avatar
I would advise swapping in the speedo head only to avoid any possible electrical gremlins.
JamesC
Old Jan 16, 2017 | 04:10 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
This might help too
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
TrevinE
Sep 14, 2015 03:20 PM
Stroopwafel
Sep 11, 2015 06:38 AM
andy74
Sep 3, 2015 08:41 AM
