Removing drain plug mats and coating floor boards
Old Jun 11, 2015 | 03:04 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Hello everyone, I'm trying to prep the interior floor boards of my GTA to put down a paint/bedliner coating and sound deadener on the floor, but I can't seem to get off the matting that covers drain plugs. I tried using a razor, gasoline, and goof-off, but none of them really worked. The goof-off worked on little tiny chunks, but not enough to really help. How do you guys remove these, and after painting the floor boards, what do you use to seal the plugs?
Also what do you guys use for a floor coating? I thought about painting it, but figured using a bedliner would be easier and more durable, and it would hold up to water if my t-tops leaked. I was going to go with this Duplicolor spray-on bedliner:
http://www.summitracing.com/parts/shw-tr250
Old Jun 11, 2015 | 07:41 PM
Steve86TA's Avatar
Car: To many to list
Re: Removing drain plug mats and coating floor boards
Have u tried a wire brush wheel on a grinder? Messy but may work
Old Jun 11, 2015 | 08:20 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
I used paint stripper. Plain gel type from homedepot, followed directions and used a metal scrapper/putty knife. Came off effortlessly!
Old Jun 13, 2015 | 02:44 AM
transaero's Avatar
I'll give the paint stripper a try. I thought about using a wire wheel but the padding would frizzle and mess up the wire.
Do the drain plugs need to be resealed with anything?
Old Jun 17, 2015 | 10:09 PM
direngrey's Avatar
I just did mine heat gun and scraper and solvent wire wheel gets tar everywhere
Old Jun 18, 2015 | 08:12 PM
transaero's Avatar
That sounds like a really good way to get the stuff off. I'll give that a try. What'd you coat the floor with?
Old Jun 19, 2015 | 03:56 PM
direngrey's Avatar
I scuffed with 100 grit put rust killer primer over any bare spots and then Duplicolour truckbed coating. I dumped a can of laquer thinner to thin it out and on it went with a foam roller and I used the spray can for hard to reAch areas. Came out nice I did 2 coats. It's not crazy thick but my floors were in pretty nice condition for a Canadian car it only got driven 2 winters in its life.
Old Jun 19, 2015 | 05:34 PM
AmorgetRS's Avatar
Agreed with heat and a scraper. I personally am using a hand held propane torch. Once it's warm it comes right off.
Frozer!!!
Jan 19, 2024 04:55 PM
Polo Z03
Sep 10, 2015 06:43 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
