swapping 82 interior into 1991 firebird
Old Jun 20, 2015 | 02:56 PM
keithtucker's Avatar
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
I want to swap the interior of a 82 firebird into a 1991, has it been done without major modifications
Old Jun 20, 2015 | 02:59 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: swapping 82 interior into 1991 firebird
Seat belts in back are different...
Not sure if early cars had the rear shoulder seat belts...
Otherwise, everything else should be fine..
Old Jun 20, 2015 | 03:17 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
how about the center console I noticed a height difference, I have a complete 82 interior I would like to install
Old Jun 20, 2015 | 03:21 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
I want to give it an old school look, I already changed the nose and taillights with only minor adjustsments
Old Jun 20, 2015 | 03:26 PM
luvofjah's Avatar
Should be fine... older cars didn't have air bags, sensor is under console on newer cars, so should have more room...
Old Jun 20, 2015 | 03:32 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
thanks, I was going to pull out the 91 steering column anyway, I also have the rally dash in great shape you think the instrument panel should fit as well
Old Jun 20, 2015 | 04:15 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Everything will swap over no problem. you will need to swap everything such as the rear plastic panels to cover the holes for rear shoulder belts, unless you are keeping the 91 rear belt set up. The one part you will need to keep with the 91 is the headliner trim that has the provision for the third brake in the hatch. You will need to swap the entire dash structure, not just fascia. You may find some of the 91 interior parts are valuable since there are a lot less of them.
Old Jun 20, 2015 | 04:38 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
thanks, that helps a lot, I just finished pulling it out, it's crazy the 82 I'm pulling it from is probably worth more, it's a 5 liter w/400 trans and a posi rear with only 61,000 miles on it
Old Jun 20, 2015 | 05:04 PM
luvofjah's Avatar
I don't know about the speedo, / dash plugs from 91 to 82...
Old Jun 20, 2015 | 08:45 PM
stealtht/a's Avatar
I assumed he was keeping the gauge cluster and wiring in the 91 to match the drivetrain , but now that you brought it up, the 82 steering column could be an issue with that, IIRC it has some unique wiring.
Old Jun 20, 2015 | 08:48 PM
stealtht/a's Avatar
Doubtful, not much desirable about 82 drive trains. 82s in general have some first year issues. Anyway, value on these cars is all about condition. Only a few special models have any collector value.
Old Jun 20, 2015 | 09:12 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
lot of plug changes, keeping the ignition key from the 91, lot of work
Old Jun 20, 2015 | 09:14 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
keeping drivetrain from the 91 intact, thanks for the help
Old Jun 21, 2015 | 09:52 PM
AmorgetRS's Avatar
You will have an issue with the speedo. 1991 uses a electronic speed while the 82 is cable driven.
Old Jun 21, 2015 | 11:48 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
thanks! that's going to save me a lot of headaches
Old Jun 21, 2015 | 11:52 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
had a few problems with the shift the 82 has the shift lock on the opposite side had to modify it and cut out the square hole to make it fit and still broke the cable
Old Jun 21, 2015 | 11:54 PM
Car: 1991 firebird
Engine: 6 cyl
Transmission: auto
I guess I have to live with the 91 speedo
Old Jun 23, 2015 | 10:52 PM
KR81's Avatar
Before/after pics ?
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Cripley
Aug 17, 2015 03:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
