Newer thirdgen dash in older third gen
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
I haven't found anything exact, but will the dash from a 90-92 match up with an 88 with no modification whatsoever? I have an 88 and somebody on here is selling a dash I'm considering buying but it's from a 92. I have an aftermarket intellitronix gauge cluster for an 88 camaro. I converted to ac but am just running the ducts that are in my non ac dash but I have everything to convert it. I am pretty sure the dashboards will both be interchangeable in regards to size and bolt locations, but I'm just trying to confirm whether or not there will be an issue with the gauge cluster area. It is slightly different, and I'm not sure if that will matter. If I have to make slight modifications that's fine, I just don't want to have to completely remake the thing. Most of the info I can find here or elsewhere is people swapping a 4th gen dash into a third gen.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Newer thirdgen dash in older third gen
As far as I know the 91-92 clusters are completely different including the shape, mounting and electronic connectors. Also difference between mechanical and electronic speedo although I don't know which the intellitronix cluster is. IIRC, the front has a different face with a flat curved clear piece (similar to the Berlinetta) vs. the earlier black plastic piece with the round holes.
https://www.thirdgen.org/forums/elec...ster-woes.html
https://www.thirdgen.org/forums/elec...gas-gauge.html
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I swapped (complete dash) from a 89 camaro to a 92. I had to remove the mounting brackets on the side and weld in the 92 brackets. The wiring harness is different also, but I was swapping from a 305 tbi to the 92 tpi so that was not an issue.
Honestly, I don't remember what the cluster section looked like when we had everything removed so I will have to check again. If it's even close size wise and as long as those 2 plugs that plug into the back of the cluster are the same, which they should be, then I can 're use the cluster circuit board because I have it wired to my aftermarket gauge panel. It's the same shape as the stock one' it just made every gauge read out digital. If I was thinking right, I would have gotten a dash first then I could have swapped in a 90-92 aftermarket cluster from the same company.
jamieriplilb
Exterior Parts for Sale
Oct 28, 2016 10:30 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
