Rear Hatch Pull down in pieces cheap fix?
Old Dec 6, 2015 | 04:33 PM
claw87's Avatar
Car: 1987 Chevrolet Camaro Lt
Engine: 5.0 305 4bbl LG4
I hear about letting the tracks down and then adding a few screws but what about welding as well? It hits a bounce and you can hear the hatch moving. Just want a cheap fix for it that adds better longevity than replacing for a new part in the same system thats bound to fail again.. Pics? Other Ideas? Thanks guys!
Old Dec 6, 2015 | 05:21 PM
dragonmas's Avatar
Car: 1987 Z28 Vert.
Engine: LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
Transmission: MD8: 4 SPEED AUTO THM700R4
Axle/Gears: GU2: AXLE, REAR 2.73 RATIO
Re: Rear Hatch Pull down in pieces cheap fix?
I repaired a unit that had been adjusted to close and then 2 tack welds added. Took me awhile to figure why it wouldn't slide with a new motor. The tacks were about as small
as a match head.
Old Dec 6, 2015 | 05:35 PM
claw87's Avatar
Mine just rides a half inch too high and is missing the actual pull down motor so I was trtying to figure out how to get the tracks down then lookng into possibly drilling two hoes addings a few bolts to shore up the problem without the hassle of finding a new part that will eventually develop the same problem and be in the same situation down the road. Manual latch conversion would be nice just getting harder to find these babies with the parts I need around my area of norcal.
Old Dec 9, 2015 | 04:32 PM
claw87's Avatar
Updated: Welded it and works better than before! Took off all the extra pull down stuff and It looks better!
Old Dec 9, 2015 | 04:34 PM
claw87's Avatar
Also after I unpluged the solenoid I noticed my latch pops every time rather than every other push of the button so It must have been grounding out somewhere. Happy with it at last!
Old Dec 9, 2015 | 04:46 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I adjusted mine and put two screws through it works fine.
Old Dec 9, 2015 | 05:04 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I just fixed mine with replacement parts from TDS and I make sure that the hatch doesn't get slammed shut. That was thirteen years ago and it still works like a champ.
Old Dec 11, 2015 | 07:45 PM
claw87's Avatar
its solid now with no play like it had before and the hatch finally sits flush on me while not making noise while hitting bumps. Its miraculous after welding the tracks.
mjdavis68
Oct 21, 2017 01:25 PM
90formulaVortec
May 26, 2016 09:15 PM
vinny R
Jan 24, 2016 01:02 AM
tommygun
Nov 21, 2015 06:39 PM
sleprock
Wheels and Tires
Nov 21, 2015 02:55 PM
