82' Z28 - When hitting lock/unlock one doors' doesn't move and the other fails to lat
Old Jun 30, 2016 | 02:12 PM
82' Z28's Avatar
Unsure of what to do, the driver side doesn't move at all except manually and passangers' side attempts to lock but doesn't latch as if it weren't strong enough but too can be manually used and work properly.
Old Jun 30, 2016 | 02:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 82' Z28 - When hitting lock/unlock one doors' doesn't move and the other fails to
Remove the door panel and take a look. There's not much you can do with the panel in place.
See of there's adjustments that can be made to compensate for wear to the actuating rods, connections, etc. It might be that the door lock actuators are bad and need replacing.
Old Jun 30, 2016 | 05:47 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Lock solenoids are either dirty or worn out - only 34 years old. Lots of existing threads on the forum about this - do a search and you will find plenty of info.
Old Jul 1, 2016 | 09:44 AM
dlinger's Avatar
Car: 1984 Z28 HO
On the passenger door I was able to roll down the window and spray wd40 in the area of the key and latch, that was after I tore the drivers apart to do the same.
Old Jul 1, 2016 | 10:28 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
So, did that improve the power lock function some or completely?
Old Jul 1, 2016 | 11:58 AM
dlinger's Avatar
Car: 1984 Z28 HO
Completely. Only been three months since I did it so not sure how long it will last. I had doors completely apart in 2012, cleaned and working good but problems returned. Proceeded to tear apart driver's door and ended up cracking the top rail. So on the passenger I looked down inside with window down and could see the area of the lock. Sprayed it and operated it manually and with locks and it freed up.
Old Jul 4, 2016 | 05:35 PM
82' Z28's Avatar
Worked superb for the passenger side, unfortunately it seems the driver side isn't hooked up so I'll have to remove its panel anyqaya.
Old Jul 6, 2016 | 11:51 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'd take the door panel apart and spray the snot out of the entire lock mechanism while manually operating it with a cleaner/degreaser. Then do the same with something heavier than WD40 like LPS 2. I did this years ago and it's still good to go. My door did the same as yours and I tried the quick fix as well. Lasted for a bit but gets gummed up again fairly quick.
Old Jul 7, 2016 | 04:04 PM
82' Z28's Avatar
This actually worked great saving me from taking the door panel off, unfortunately I couldn't get the driver side going and removed its' panel to discover the actuator had broke. But thank you all regardless
bigarmzz
Wheels and Tires
21
Jun 26, 2022 12:34 PM
epsmotorsports
Jul 15, 2016 03:27 PM
Sandovaljr2007
Jun 28, 2016 11:59 PM
santiclause
Jun 27, 2016 04:11 PM
89firebird
Jun 15, 2016 06:16 PM
