Can't figure out how to remove gauge bezel
I tried searching all over the forums and YouTube. I found a lot of walkthroughs for the Camaro, but not the Firebird. I have an 85, I removed all the screws along the top, removed both panels under the steering column and the related screws there. I found the screws behind the switxh panel for the fog lights. But I can't find anymore screws and the bezel won't pop off.
I feel like the remaining screws are behind the switch panel with trunk and defroster buttons, but I can't get to them. Do I have to remove the center console and radio to get to them? Any help is appreciated.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Can't figure out how to remove gauge bezel
I'm sure you have to remove the panel with the rear defrost,hatch button and sub switch.the rest of the retainers are behind that,then pull on the cluster(it's plugged in)
You don't have to remove the console or radio.
http://www.hawksmotorsports.com/dash...trans-am-used/
it looks like that panel is part of the bezel. I could be wrong though.
Engine: 5.0 EFI
http://i166.photobucket.com/albums/u...pslsph4flo.jpg
I really forget how I did get one out.I sold this to a member here a while ago.over on the left side it appears to be where another retainer would be.
Engine: 5.0 EFI
I'll PM DynoDave he 's the one I sold it to and either him or I will get back to you ASAP
Engine: 5.0 EFI
he'll get back to you asapI am having a total BrainFreeze
Engine: 5.0 EFI
I just checked mine(86) it looks like you have to remove the panel under the pouch on the passenger side
Engine: 5.0 EFI
Axle/Gears: 10 Bolt 2.73 Open
There most certainly is one back there. But when you said you gotten the one on the right, I thought you meant that one.
You can see that tab in the second picture here.
https://www.thirdgen.org/forums/memb...ml#post6053111
And in the far left side of the second photo in this post.
https://www.thirdgen.org/forums/memb...ml#post5901182
Excellent. Glad that was it...because I had no other ideas!
Engine: 5.0 EFI
Thanks Dave for chiming in.
Engine: 5.0 EFI
I had a little brain freeze,it needed a little melting.
Axle/Gears: 3.45, 3.27, 3.27
Yep, just pulled the gauge cluster out of a 89 Firebird today. There is a hidden screw behind that lower valance on the passenger side. Lots of screw to remove. You think you've got them all and it still won't come out. Glad you got it.
Lon
Lon
glad we could help ya
