Interior roof trim by hatch
The trim piece in my interior that goes across the top of the hatch is missing a few screws. Are there oe screws that i could purchase, would hate to put screws in that dont match.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Interior roof trim by hatch
As far as I know they are just normal Phillips head trim screws that you should be able to find at any local hardware store.
Are they missing, or is the plastic broken out around the screw hole?
The screws are just a black Phillips finish screw. You probably don't want 100 of them, but here you go. From the book of Auveco... The 1/2" is probably about right.
Are there any good fixes if the plastic broken out around the screw hole?
Car: '87 IROC
Sand the back side of the hole flat, rough up the area around the hole to give it some tooth. Then cut a 1" square piece of scrap ABS. 5-minute Epoxy the ABS square over the oversize hole. Drill an 1/8" hole in the right spot, follow up with a countersink. Easy and effective.
Thanks.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
A even better fix is some of those interior trim screws with the built in washers that you can find in the HELP section of your local parts house. They are in black or chrome.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I forgot to mention that u could hot glue washers on the backside of the panel to prevent the hogout of the holes in the panel.
