Need carpet opinion
Old Mar 28, 2018 | 04:04 PM
Desertvert87's Avatar
Need carpet opinion
Where is the best place to buy carpet for a 87 gta convertible
Old Mar 29, 2018 | 01:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Need carpet opinion
1Aauto had the best prices. I went with this ACC:
https://www.1aauto.com/1985-92-chevy...=774416&y=1991
I had a bad experience with it. The carpet I received had no cutouts so I had to cut everything. I would have requested that they swap it and eat shipping costs both ways but I didn't open it until 2 months later. The fitment was also sub-par for me. The carpet is raised up an inch from the transmission tunnel. Not much I can do about it. Lots of other members have no complaints about the ACC capret though so I may be an outlier.
Old Mar 29, 2018 | 01:22 PM
82tarecaro's Avatar
When you order it, take it out of the box right away to avoid creases, even if you are not installing it for awhile. Also, use a steamer to soften it as you install it. You can also use a heat gun on the backing if you are careful.
Old Mar 29, 2018 | 01:40 PM
Degweiser's Avatar
Car: 1992 camaro z28, 1988 camaro sc
Engine: 350 tpi, 305 tbi
Transmission: t-5, t-5
rock auto
Old Mar 29, 2018 | 11:39 PM
Thanks for the referrals guys and the tips much appreciated
Old Apr 15, 2018 | 07:09 PM
sshoureas's Avatar
The biggest tip I can offer is to spring for the extra dough to get hte "mass backing" option. It'll make fitting and laying carpet easier and you can virtually install it out of hte box as the rubber backing has a memory and will snap back into shape almost as soon as you take it out of the box. Well worth the extra investment plus it helps sound deaden.
Old Apr 21, 2018 | 03:10 PM
Thirdvert89's Avatar
Sshoureas what place can u recommend for this carpet you are referring to
Old Apr 22, 2018 | 02:55 AM
sshoureas's Avatar
ACC Carpets, Stock Interiors, Hawks Thirdgen, 1A Auto, etc ... they should all offer it. I think there's only a couple companies actually making the carpet although several selling it ...
Old Apr 22, 2018 | 03:03 AM
  • thanks so much
Old Jan 3, 2019 | 02:38 PM
92Annie's Avatar
Car: Black 1992 Z28
Engine: 350 TPI L98 N10
Axle/Gears: 3.23 GU5 G80 G92
Hey sshoureas, thanks for the info! When I was looking at carpet choices I had the option to choose mass backing as well as loose padding. Are these two options both insulation, do I still need the padding with the mass backing? After accidentally setting my Z on fire I need to replace both the carpet and the insulation and only want to go through this process once lol.
Old Jan 3, 2019 | 02:55 PM
sshoureas's Avatar
I haven't re-carpeted an f-body so I'll guess a tar paper like insulation might be available to lay down in several pieces before laying the molded carpet down. That's the way it went in my 1976 Grand Prix 50th Anniversary. In my 1987 IROC, the PO owner re-carpeted it but didn't spring for the mass backing so it isn't nice, tight and smooth like my Grand Prix so it's a bit wrinkly.
Old Jan 3, 2019 | 03:25 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I installed 1aauto, dark med grey carpet in around 2000-2002 and it fit pretty good. I left it out in the sun while I pulled the old. I had put in dynomat (well knock off) and some additional insulation so that made some of the tight corners a little tricky. After about 5 years I noticed a slight purple tinge to the color in a few spots I assume fading and it was in spots that get wet from shoes and the hatch when you open it in the rain. At the time it was daily driven and parked outside. Mine had the heavy rubber backing and the padding pre glued to it. I did use too much spray adhesive while installing it so that will make take two a little interesting.
But to be honest it still looks better than the factory carpet did in 2000. The foot pad for the driver has stayed in good shape.
Only trimming I had to do was door edge and center console area. I believe at the time I ordered it without the cut outs in the center console but I could be wrong about that. The only wrinkle I never got out was in the well in the trunk area but without extra insulation I don't think that would of been an issue... or if I had used a heat gun... I know a lot more now than I did then.
kobrak
Jun 12, 2009 12:02 PM
2camaros1kid
Jan 9, 2005 05:13 PM
Blazin91Z28
Feb 16, 2001 01:27 PM
redcamaro83
Feb 9, 2001 12:35 PM
