What size fuses?
Old Dec 14, 2018 | 01:50 AM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
What size fuses?
Hi all.
Im looking online to replace all my fuses. I dont know how old all of mine are but the car is 32 years old.. so just for the ease of mind, I thought to replace them all. I saw on amazon, there were many different sizes. Does anyone know what size our cars have? Ive got an 86 sport coupe.
Old Dec 14, 2018 | 01:58 AM
Drew's Avatar
Re: What size fuses?
They don't go bad with age. Unless there is a short and they melt, they will last forever.
Old Dec 14, 2018 | 01:59 AM
Engine: 383 Stoker
Yeah, I know. I just thought it would be good to replace them. I just bought a test light (i think theyre also called circuit tester?). But do you know what size I need? for fuses that is
Old Dec 14, 2018 | 04:03 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
The fuses are marked on each end, between the two little test terminals. The color is also an indicator.
Old Dec 16, 2018 | 05:39 AM
sshoureas's Avatar
Seriously Dude, they don't go bad. You can relax
Old Dec 16, 2018 | 08:10 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
If this is a serious post and you are really replacing your fuses, you replace them, like for like. Pull a 20 amp fuse, replace with a new 20 amp.
But why? They do not go bad on their own over time.
Also, check your owners manual to be sure what’s in place, is the proper rated fuse.
Old Dec 16, 2018 | 02:43 PM
Drew's Avatar
Shouldn't need the owners manual. The amperage is usually printed on the fuse block next to the description.
But yeah, just grab a hand full of fuses at the pick-n-pull, or start collecting them when you junk a car... Or if you're fortunate to have crazy relatives who clean out their junk drawers, just wait until they bring you a coffee can full of 40amp Maxi-Fuses that are new in the package because they bought half a dozen that one time when their car blew a fuse... Then when you pass away, someone else can take possession of those 40amp Maxi-Fuses because you'll never in your life need half a dozen Maxi-Fuses...
I'm only half kidding, 20 years of car enthusiasm, I have a box full of spare bulbs and fuses for all kinds of cars. They just kinda show up and get assimilated into the collective.
Old Dec 16, 2018 | 02:47 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
You do not need to replace fuses due to age. Seriously. If you do this, you might as well replace your entire car, it's all just as old.
Old Dec 16, 2018 | 03:17 PM
Drew's Avatar
See? It's funny cause it's true.
hungry4des
Aug 19, 2002 06:47 PM
85ws6TA
Car Audio
Oct 20, 2001 11:34 AM
MATEOZ28
Car Audio
Jun 21, 2001 07:16 PM
Hctv19
Car Audio
May 29, 2001 10:03 PM
Aaron91RS
Car Audio
Sep 30, 2000 10:28 PM
