Fuses keep blowing...
Old Oct 18, 2001 | 08:41 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
so i have my 4gauge wire running about 10in. to my 150amp blade fuse, running roughly 12 feet to my distribuition block. from there it runs to a 40amp fuse to my Directed 1100d with 4gauge all the way.
when ever i try to put the fuses in the amp they pop like hampsters in a microwave. the ground is also 4gauge running to my ground block.
my other amp is working fine. its an alpine MRV-F307 V12 amp that im using on my fronts and rears.
im baffled as to what it could be. the 1100d worked fine when all i had was it and i ran the power wire directly to it and the ground wire from it. basically it was the only amp hooked up and there wasnt a fuse block or ground block.
Im wondering if the fuses arent big enough, but the way the amp fuses pop it looks like even if i tried an 80amp it would kill it.
Old Oct 18, 2001 | 10:13 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Even if the fuse is too small, it wouldn't blow until the amp was pushed. Sounds like there is a short somewhere. Check the positive wire from the fuse that blows to the amp and make sure its in good shape. But there may be an internal short in the amp.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
[This message has been edited by Justins86bird (edited October 18, 2001).]
Old Oct 19, 2001 | 12:09 AM
85ws6TA's Avatar
well 1st it blew the fuse near the battery when it was only a 30 amp, so i changed it to a 150 amp blade type fuse. then it fried the one in the fuse block, which was also a 30, so i replaced it with a 40. then it fried both in the amp and they are both 40s. and i dont think its the amp because i was using it 2hrs before all the trouble, and it was working fine. it did only have the 1 30amp near the battery though. im gonna try my other 1100d to make sure, but i kinda hope it does the same thing because i dont want to have a bad amp.
Old Oct 19, 2001 | 02:10 AM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
i dont know too much about this stuff, but i do know that no one in my area will install a system without using a 200 amp fuse, i got a few friends with 6-8 amps all crazy **** n that what they use is a 200 amp fuse and it never blows, also makes you think how can you run 2000 watts of power in amps comming throgh a 2oo amp fuse, but some how it works.
maybe give that a shot, it could be it.
http://PCperformance-usa.com/86bird/86bird.html
Old Oct 19, 2001 | 02:12 AM
Guest
Posts: n/a
also they all seam too use welding wire for the power and ground.
like arc welder wire.
Old Oct 19, 2001 | 02:18 AM
KlayBuRn's Avatar
hook up a circuit breaker fuse and watch for smoke
Old Oct 19, 2001 | 06:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
if you're popping 30 amp fuses with the amp off, like mentioned, you've got a short. Either that or the amp is cooked hardcore. Do you have the amp wired properly or are the + and - switched? If it's wired properly, unhook it and pop the fuse in. If the fuse still blows, the amp isn't the problem. If the fuse doesn't blow, your amp did.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 20, 2001 | 11:34 AM
85ws6TA's Avatar
well i just un kkooked everything and re-wired it, and it works now. such a relief. im glad i didnt blow my amp. im figgureing it had a short somewhere or like jim said i may have had the + and - backwards. not likely but possible. thanks for the help though.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
