15 minute seat belt trim fix
Old Jan 10, 2019 | 07:18 PM
Alfisti's Avatar
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
I stole this idea from someone on here, but I thought I would share how I did it.
All the tabs were broken off the trim that covers the retractor in the roof. So both trim pieces were flopping around and getting in the way.
Since I didn't want to cut them off or cut new ones to put them on I decided to just screw the trim to the roof.
There is a small hole in the retractor assembly in the roof that looked like a perfect place for a screw.
But I figured aligning the trim properly would be the hardest part. Until I saw this little dot in just the right spot. Like GM had thought about adding a screw in some situations.
So I used that hole as a guide and drilled a small hole for a small screw.
Once you have a hole, line up the trim properly and screw it in. The screw is behind the belt so you don't see it. A black screw would be even better, I just had these lying around.
Voila! No more floppy trim!
I hope this helps someone else with this issue.
Ian
Old Jan 10, 2019 | 07:56 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: 15 minute seat belt trim fix
Great idea! What size bit and self tapping screw did you use?
Old Jan 10, 2019 | 10:58 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Good to know!
Old Jan 11, 2019 | 07:26 AM
Abubaca's Avatar
That IS a cool little fix. Mine pop out every few weeks. I pop 'em back in but a permanent solution wouldn't hurt. ....and it wouldn't take much to dab some colored paint on that screw either.
Old Jan 11, 2019 | 09:49 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The replacement ones have a split in them, you just cut off the old one and slip the new one on. You don't have to cut the new ones. Though the screw solution is much cheaper if the trim looks good and is just missing the clips... much better than having them flop around. If you paint to match it probably looks better than the replacement part anyways.
Old Jan 11, 2019 | 10:13 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Great fix! I did the same thing last August on my car. I had some extra OE self-tapping interior trim screws laying around so that is what I used. Drilled the small hole, then beveled it slightly to let the screw recess into the plastic just like the other trim pieces do.
Old Jan 11, 2019 | 08:53 PM
BIRD91ZRAG's Avatar
Looks to me to be a number 8 screw, which takes an 1/8th inch bit. Great idea!
Old Jan 12, 2019 | 10:13 AM
texascat2's Avatar
Cool, thanks!
Old Jan 12, 2019 | 06:06 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Sick of my trims flopping around! Excellent fix!
89RS_82Z
Interior Parts Wanted
Jan 23, 2008 08:27 PM
SgtSkip
Oct 9, 2003 02:36 PM
dd85T/A
Apr 23, 2003 12:25 PM
Psaitta800
Nov 26, 2002 06:55 AM
ryn28
Feb 19, 2002 06:17 PM
