E brake rubber/ guide/ brush/ dust cover/????
Old 12-27-2019, 05:40 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Not sure what to call it but what is the part the e brake handle goes through?
I was cleaning up my console to re-install and realized I don’t have it. Not sure if I ever had it for this car.
I remember it being attached to the console plate and being kind of a strip of rubber with a slit in it from my other third gens.
anyone got a pic? Where to buy? How to attach?
Old 12-27-2019, 05:52 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Re: E brake rubber/ guide/ brush/ dust cover/????
You would probably have to buy an entirely new upper console. IIRC from when I had a Camaro it was just basically a piece of rubber with a slit sandwiched under a second piece of plastic that was glued in place. Should be pretty easy to fabricate from a strip of rubber or automotive vinyl.
Old 12-27-2019, 11:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I redid mine and used those short torx screws used in our interiors to hold it in place.Normally there's a plastic rivet there, but you have to break it to remove/replace the flap.
WildCard600 (12-28-2019)
Old 12-28-2019, 10:48 AM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
The rubber and retainer are missing on mine. I think I can fav something up though after looking at it closer.
thanks for the replies
gt4373
01-18-2018 10:34 PM
sleprock
07-01-2015 10:43 AM
tom1985
09-25-2013 07:17 PM
IROCZ88x
02-12-2003 09:29 PM
Quick Reply: E brake rubber/ guide/ brush/ dust cover/????
