4th gen seatbelts
Old Apr 10, 2020 | 11:49 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
4th gen seatbelts
My original belts were shot so I decided to go with 4th gen belts. For one because they were easier and cheaper to find and because they only have a retractor in the roof. They are pretty much a direct swap. One thing you need to do is remove the plastic cover from the original lower retractor. Do this by drilling the rivet out of the cover to the retractor. You will then have to cut the belt to remove the plastic cover. The 4th gen belt will need the plastic cover trimmed some where it mounts to the floor so you can get it through the hole in the original cover. I don’t have pics of this but you will see what you need to do once you have the parts. The one issue you have to deal with is how to hold the original cover in place. I made a bracket that is held on by the seatbelt bolt. Then you put the cover over and drill a new hole through the cover and into the bracket. The seatbelt still needs put in there again but was just showing how I did this without the belt in the way.
Old Apr 10, 2020 | 01:48 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: 4th gen seatbelts
Very nice write up, wish I would've thought of that years ago lol.
I have a 4th gen belt on the drivers side of my car, but the bottom is unmodified and bothers the crap out of me every time I look at it, between the plastic cover on the belt itself and the hole that is created by removing the original lower cover.
Maybe this is a good opportunity to fix the twist I have in the belt. Pretty sure the one I got may have been made incorrectly because I know I installed it correctly.
Time to hunt down a new lower cover...
Old Apr 30, 2020 | 11:30 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I just used the original bracket that held the retractor. I did grind a spot so the 4th gen belt hold down tab would fit where the torx bolt goes through.
Old Apr 30, 2020 | 11:33 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Old Apr 30, 2020 | 11:50 AM
Car: 85 Berlinetta
That works too. My whole retractor and belts were all rusted and moldy so they just got pitched. My little bracket works so that’s all I care about.
Old Apr 30, 2020 | 01:13 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
That's a pretty cool mod. However, as an owner of an 82 Trans Am, this gives you essentially the same "comfort" as the 82 where the belt bolts to the floor and there is no floor retractor. I personally am not a fan of the belt never being comfortable which is why I upgraded mine to dual retractors like the later cars. Still, I guess if you had nothing else, this works!
Old Apr 30, 2020 | 01:26 PM
Car: 85 Berlinetta
It came down to I got a set from the 4th gen for $50 shipped. To get an original setup would have cost me $150 or more for ones in nice shape.
rottweiler68
Nov 8, 2017 02:22 PM
Dustin Imports
May 20, 2010 04:24 PM
MARO-MAN
Dec 17, 2006 11:35 PM
irocyourpants
Jul 6, 2005 03:30 PM
Trans Damnation
Feb 16, 2003 06:00 PM
