Inside pillar seal
Old Apr 14, 2020 | 10:42 AM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Inside pillar seal
He all
So I am gearing up to get my interior fixed up for this spring/summer. My original pillars are in perfect shape plastic wise. However they both have an inside rubber seal that is cracked. See pic. Just wondering can I replace these seals and if so what woudl be best to use? A new pair is $139 listed on eBay. Trying to save some money!
Old Apr 14, 2020 | 10:45 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Inside pillar seal
I can't help directly, but I was just looking at those on my car this weekend. There are many companies that sell universal seals that could be made to work. I have found 90* L profile seals that I will probably go with. If you do a search you should be able to find something.
Alternatively, you could probably go to Home Despot and get a thick, closed cell foam, weatherstrip intended for home use that could be suitable replacements.
Old Apr 14, 2020 | 10:55 AM
Engine: 5.7
Axle/Gears: Stock
ok good to know. I will look for the same seals you are suggesting. thanks Scooter!
Old Apr 14, 2020 | 10:57 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I would provide a link, but I am not on my usual PC
Old Apr 14, 2020 | 11:04 AM
Engine: 5.7
Axle/Gears: Stock
When you get a chance that would be great sir!
Old Apr 15, 2020 | 09:05 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
https://www.thirdgen.org/forums/inte...ulding-re.html
Old Apr 15, 2020 | 10:58 AM
Engine: 5.7
Axle/Gears: Stock
Originally Posted by blacksunshine'91
Lot of good info in there thanks!
Sadly as always with Ali Express the items suggested are not available anymore. Typical with that site.
Old Apr 15, 2020 | 11:09 AM
Drew's Avatar
JCWhitney catalogs used to have a couple pages full of generic weatherstripping.
Old Apr 15, 2020 | 01:03 PM
Engine: 5.7
Axle/Gears: Stock
Old Apr 15, 2020 | 01:06 PM
Engine: 5.7
Axle/Gears: Stock
JCWhitney... I rebuilt my entire 1971 Jeep CJ-5 with many parts from them, back in 1990.
I will check them out, thanks!
Old Apr 15, 2020 | 04:20 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I can't find the site I had been looking at in the past. I was looking at an L profile for a secondary door seal for my 69 Suburban and truck.
Something like this should work though
https://www.zoro.com/search?variants...Rubber%20Seals
Oh wait, this was what I was looking at
https://www.trimlok.com/rubber-extru...iangle-section
Old Apr 18, 2020 | 03:29 PM
Engine: 5.7
Axle/Gears: Stock
the 2nd might be fine. Its obviously available being you can buy this pillars new with the seal on them already.
Old Apr 18, 2020 | 03:39 PM
Engine: 5.7
Axle/Gears: Stock
Old Apr 18, 2020 | 03:41 PM
Engine: 5.7
Axle/Gears: Stock
I found this:
https://therubbercompany.com/wp-cont...L-Profiles.pdf
look at number RCAP12X12L. Its 1/2" both sides. I emailed them to see if anyone can order a minimum length
Old Apr 18, 2020 | 04:14 PM
Drew's Avatar
You'll probably want to get a sample to determine if the rubber is soft enough to conform like weatherstripping.
Old Apr 18, 2020 | 04:33 PM
Engine: 5.7
Axle/Gears: Stock
Good point
The 3m seal Scooter listed is 233 bucks a roll. Might as well buy replacement pillars at $139 for the pair off eBay.
Old Apr 18, 2020 | 04:42 PM
Drew's Avatar
Or simply leave that strip out. It's not like it keeps water out of the car. It might make a minimal impact on the ability of the A-pillar trim to rattle, but it's more likely to fill the visual gap. Put a foam rubber donut between the clip and the hole in the sheet metal, and glue a strip of black paper the length of the A-pillar, and you'd probably have the same effect for a few bucks.
Old Apr 18, 2020 | 06:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I kinda like the RCAP28X26L a bit further down in that link.It resembles more the stuff i bought from HD, but maybe not as thick.
Old Apr 18, 2020 | 07:23 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Originally Posted by Hawkeye1980
Good point
Depends which adhesive you get. The other adhesive is much cheaper.
I was looking at that stuff for a different project
nbressette
Aug 21, 2018 06:44 AM
Steven6282
Jun 21, 2011 09:54 PM
da_jester
Dec 9, 2008 02:15 PM
spills
May 23, 2006 11:24 PM
d4nk
Oct 13, 2002 03:49 PM
