Help! My cluster was attacked by a Red neck
Old May 4, 2020 | 04:43 PM
BuckyBadgerRS's Avatar
Car: 91 Rs
Engine: 327 SBC
As you can see the cluster has been rednecked up. It's a 91 RS that came factory with the v6. It now has a 327 SBC and a 700r4 I'm told was taken from an 85. I would like to unredneck my car in one of two ways. Either buy a not cobbled factory gauge cluster or buy an intellitronix cluster. The questions I have are
1. Does intelitronix remedy the inaccurate tach issues
2. Are the pre 91 clusters plug and play with other years with the exception of the speedo.
3. If I ordered the intellitronix cluster would I order for a pre 91 car?
4. Are there adapter kits to make my 85 trans work with a 91-92 cluster?
Old May 4, 2020 | 04:54 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: Help! My cluster was attacked by a Red neck
I don't think your description of a persona is really all that accurate. I've seen people from all walks of life really F up these cars, so I wouldn't put to much into one generalization. In my opinion, just keep it simple and get another cluster. Pretty sure there are 3-4 on Ebay right now.
Old May 4, 2020 | 04:59 PM
Car: 91 Rs
Engine: 327 SBC
Where I live red neck'd is just a term for cobbled, sorry if that isn't PC enough. I appreciate your opinion but I was seeking more information so I can replace the cluster. With there being multiple changes to this car I wanted to seek others advice prior to ordering a cluster that isn't going to work for my application.
Old May 4, 2020 | 07:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Does the tach work at all? You can swap the later non cable clusters no problem but you have to stick with V6 cluster for V6 engines and V8s the same way for the tach to work right. Since the speedo is working I'm guessing the cable is still hooked up. I think RBob knows about making mismatched things work? I have a tested good 91 V8 cluster from a V8 but you need more info to make it work and sorry, I don't have that.
Have fun!
Old May 4, 2020 | 09:34 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
As a white man, I will give you a pass to use the R-word.
Old May 5, 2020 | 07:34 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
this was likely done because the swap transmission did not have the electronic speed sender that the original cluster needed.
make sure you have those pieces/parts, they're getting scarce from what I hear...
Old May 5, 2020 | 07:46 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
There are rednecks in Wisconsin?
Old May 5, 2020 | 02:00 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The only Camaro cluster that will fit in your car is a 90-92 cluster; nothing from 82-89 will work ----> PROPERLY !
If there was no signal converter installed after the engine swap; your current V6 tachometer reading is off by 25% (or was it 33% ?) You would need to use a V8 tach or install a tachometer signal converter.
To correct this "hackery" you'll need a 90-92 electric tranny VSS, ( made for automatic: the correct version so the proper plastic speedo gears fit & match the rear end gearing ) and a V8 cluster.
Old May 5, 2020 | 03:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, John in RI is the one I meant to refer to as the guy who knows how to get this working if anybody does. OOPS, mental lapse from too much time sitting on the couch in my bathrobe, eating bon bons and watching TV. Yawn...
Old May 5, 2020 | 03:40 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
On the other hand, this is a shining example of the "I'm offended" persona
Old May 5, 2020 | 10:44 PM
John in RI's Avatar
Cluster problem threads are certainly the kinda' threads that I post into all the time. Dealt with a lot of conversions, customs installs and swaps 'along the way' and it's a topic I'm lucky enough to be able post (a little) experienced & (usually) accurate feedback about.
Old May 5, 2020 | 11:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
To be fair, he never said he was offended, but rather pointed out that lots of people from all walks of life have hacked up these cars...
Old May 6, 2020 | 01:10 AM
Car: 1985 Z28
it's a Thirdgen man. The whole ******* ****** thing comes with the territory.
Old May 6, 2020 | 10:57 PM
gscroll's Avatar
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
There are other aftermarket places besides intellitronix that you can go to for new gauges. It really depends
on the route that you want to go. John in RI is actually working on an item for me right now since I wanna
keep a stock look. If you want something different you could look into other vendors that sell aftermarket parts
or you can do a 4th gen swap. Each has their pros and cons and at the end of the day its your car.
Old Nov 8, 2020 | 05:53 AM
Dreamsover2's Avatar
Car: 92 Camaro Rs
Engine: 5.0
Axle/Gears: ?
Hey I just stumbled on this thread and have some questions,,, have a 92 RS that i just got a couple of months ago... just after I got i noticed the Odometer quit but speedo works. yesterday the speedo quit working for a couple of miles and then started working again. I am not familar with this system at all as I previously thought it was a mechanical unit...
What or where do i need to go to remedy this?
Old Nov 8, 2020 | 11:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You know, if you guys didn't name yourselves 'Kentucky KITT car' and 'Bucky the Badger' then it might be easier to take you seriously when you two argue about the use of the word red-neck.
Old Nov 8, 2020 | 01:38 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Old Nov 10, 2020 | 06:42 AM
Car: 2 T-Tops
Engine: 327/305
Okay then, new COTM editor that can't even get my screen name right.
Old Nov 10, 2020 | 06:58 AM
NCFarmLife's Avatar
Car: 91 Z28, Black and Grey, T-Top
Engine: 5.3L LS-Swapped
As a NC-area red-neck. I also approve of this message... we wear it as a badge of honor down here. YEEHAW!!!
Alfisti
Dec 8, 2018 07:26 PM
benscool1
Oct 8, 2009 11:51 PM
tireburningZ
Mar 11, 2008 05:39 AM
xplane
Sep 19, 2004 08:13 AM
