92 camaro hatch pull down issue
Old Jan 9, 2024 | 02:44 PM
pyledriver's Avatar
92 camaro hatch pull down motor makes noise when I push down on the tab but the assembly does not move.
Kinda sounds like a loud hum coming from the assembly with no movement. Tried to move the assembly up and down by hand when the motor runs, When doing that the noise will get quieter but still no movement. Im sure I will need to open my wallet for a fix but I can only find parts for a 91 and earlier, nothing for a 92. What is the difference from 91-92? I can open and close hatch with key but it is a loose fit and not closed properly.
Old Jan 9, 2024 | 04:00 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 92 camaro hatch pull down issue
92 used a completely different style pull down than the 86-91
Old Jan 9, 2024 | 04:08 PM
pyledriver's Avatar
Thats what I am understanding. Can I convert to a 91 style? Or does anyone know where to get the correct 92 parts? I already checked hawks and a few other vendors with no luck. Thanks
Old Jan 9, 2024 | 04:37 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
It sounds like the plastic gears are worn out.
Somebody was selling one here awhile back.
Old Jan 9, 2024 | 04:54 PM
pyledriver's Avatar
Thanks, I did read on this site that the 91-92 share the same gear, I was hoping someone could confirm that b4 I start throwing parts at it
Old Jan 9, 2024 | 07:28 PM
my82roc's Avatar
86-91 uses a different mounting bracket so in order for you to switch units you would need the mounts along with the pull-down
Old Jan 10, 2024 | 12:54 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
The plastic gear is the ONLY part that's identical between the two units. My 88 has the "old" unit and my 92 has the "new" unit and both of them had a stripped/broken plastic gear a while back. So I know for sure that they are identical.
Old Jan 10, 2024 | 05:31 PM
pyledriver's Avatar
Thanks for the info, I found old threads on this site that does confirm that they use the same gear. Thats the only part that they share.
Old Jan 15, 2024 | 02:34 AM
Nsty_6.2's Avatar
Car: 1989 Chevy Camaro
Engine: 6.2 376l LS3
Transmission: 4L80E 3k stall
Go over to Top Down Solutions and get an upgraded housing unit, they have metal frame for reinforcement. The one I bought was Part# 300310 for $123. Included are the nylon guides, the gear nut, new style reinforced motor housing and a packet of synthetic grease. If your motor is still good they have a unit without the new motor and the kit is a little cheaper.
Old Jan 15, 2024 | 03:53 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
This doesn't work for the 91.5 to 92 cars.
Old Jan 15, 2024 | 06:13 AM
Nsty_6.2's Avatar
You could buy the Latch assembly hatch pull-down unit from the 88-91 and use the previous part mentioned, Part is like $35 and you wont have to worry about finding the parts, if that helps.
kaitlin
Exterior Parts for Sale
Sep 23, 2013 04:30 PM
RallySportin'
Mar 15, 2004 10:15 AM
