Water leaking in passenger rear seat
Old Feb 25, 2024 | 08:20 AM
Shaunejulian's Avatar
Car: 1986 Blue Iroc Z TTop
Engine: 305 LG4
Transmission: 5speed
Ok so I have a 1986 TTop Iroc Z. I had water leaking in the rear seat. I replaced both rear hinges, hinge gaskets, hinge bolts, and new rear hatch seal. Also, I made sure the hatch is adjusted perfect. The hatch motor does not work for the auto pull down. I noticed today I still have water spots in the rear seat from recent rains. Can anyone guide me on where to look next? I plan on replacing the t top seals as well. Appreciate any help.
Old Feb 25, 2024 | 10:20 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Water leaking in passenger rear seat
You really need to pull the trim and headliner and have someone run a garden hose over ttops and hatch hinge to body area.
the hinge to body needs a sealant around the bolts and between the washers/spacers or water leaks down in there.
The ttops can cause water back there if the sealants have gone bad. Its not always the seals.
Old Feb 28, 2024 | 11:15 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Maybe - Just Maybe --------> Check the screws that were used to install the rear headliner trim panel.
These screws should be VERY short. I once had a car where the previous owner installed screws that were too long and put holes in the roof. The holes he made were "hidden" in the channel under the hatch glass,...only found them after removing the headliner screws and seeing how long they were.
Just 1 more place your leak *MIGHT* be coming from !
Old Feb 28, 2024 | 11:26 AM
Engine: 305 LG4
Appreciate it I will be pulling headliner and trim this weekend to check for leaks.
Old Mar 1, 2024 | 06:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
When I had water on my back floor passenger side ,it was my T Top leaking.
Old Mar 11, 2024 | 09:30 AM
Engine: 305 LG4
Wanted to give an update. I pulled the ttop seals out and discovered two rust holes in the channel. That is where my water was coming from. I patched the wholes and will be installing new ttop seals this weekend.
FrankieFF
Dec 8, 2023 09:10 PM
MTPFI-MAF
Feb 6, 2004 01:37 AM
Paul Riccioli Jr
Aug 7, 2003 11:46 AM
Andy Fanshawe
Jul 26, 2003 10:57 AM
Conman
Mar 4, 2003 06:55 PM
