DD8 mirror belt
Old Mar 15, 2024 | 10:33 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
DD8 mirror belt
Anyone know of a replacement or solution to a loose/stretched belt? My mirror motor spins and labors through a few cycles then starts getting better. Took a look and the belts fighting for grip. Wondering if there's anything aftermarket that'll work.
Old Mar 15, 2024 | 08:34 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: DD8 mirror belt
I've never even tested mine to see if it works. I know it gets power because the green light lights up, but I've never heard any noises from it. Where is the sensor?
Old Mar 15, 2024 | 08:59 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: DD8 mirror belt
On the back of the mirror by the plug
Old Mar 15, 2024 | 09:07 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: DD8 mirror belt
There is a sensor on the front and the back.
I believe the motor is suppose to run when the green light is lit
Old Mar 15, 2024 | 11:58 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: DD8 mirror belt
The belts look like o-rings. You could probably find something to work. I fixed one that way years ago, worked well enough for several years.
Old Mar 16, 2024 | 03:32 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: DD8 mirror belt
I may try shining a flashlight into it to see if it does anything. I never drive the car at night so I've never paid much attention to it.
Old Mar 16, 2024 | 06:55 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: DD8 mirror belt
Well I tested mine by shining a light into the sensor and it doesn't do anything. The little light above the near/far wheel lights up, but the LED next to the switch doesn't.
Old Mar 16, 2024 | 10:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: DD8 mirror belt
Did you rotate the wheel to the "far" position? This is the most sensitive setting. The lower the number, the stronger the light has to be. Even if one of the belts snaps. Sometimes you can hear the small motor, even if the mirror doesn't pivot.
Old Mar 16, 2024 | 11:14 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: DD8 mirror belt
yeah I tried that. I'll try it again and listen a little closer. Do the headlights need to be on, or does it make a difference?
Old Mar 16, 2024 | 11:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: DD8 mirror belt
The mirror reacts to headlamps behind you, not your headlights. Thats from the sensor next to the power switch. The dial affects that sensor.
The sensor on the back of the mirror works mostly in daylight as the sun is brighter than any headlight from a vehicle behind you (during the day). The headlights would not cause the mirror to change to night mode. At night w/ no sun the front sensor wouldn't really be working. So any headlights behind you would then cause the mirror to switch/pivot.
Another thing you may want to do is block the front sensor when you test the mirror. This will keep any daylight from over riding the flashlight on the rear sensor. Which ever sensor has the brighter light that sensor over rides the other
Old Mar 17, 2024 | 06:40 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: DD8 mirror belt
Found these on Amazon. The one pack where they all look the same I used for the smaller pulley and took the smallest one from that mixed pack for the larger pulley. The mixed pack are square belts but it works. My mirror works as those it's day one again. For a little over $20 I have a working automatic mirror.
1989karr
Dec 19, 2005 01:02 PM
jandl22
Oct 17, 2005 07:48 PM
biggtime
Jul 6, 2004 10:42 PM
jfox55
Aug 21, 2002 07:24 PM
