Hole in Dash
Old Jan 5, 2025 | 04:12 PM
pete2833's Avatar
Car: 1986 Camaro Iroc
Engine: 5.0 TPI
Hole in Dash
Well, I'm going through the 85 Iroc I just purchased. Car has been sitting since 2008. The guy i bought it off of, bought it and parked it. Didn't know too much about it.
Well there was a Iroc sticker stuck on the dash. I removed it to find a hole in the dash !! I would say the only way to repair this is to replace the dash.
Pete
Old Jan 5, 2025 | 06:08 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Hole in Dash
Find a broken dash and cut i small piece big enough to match the hole (w/ no gaps). It should blend in quite well being under the vents, that area doesn't get much light or attention.
Old Jan 5, 2025 | 06:20 PM
pete2833's Avatar
Engine: 5.0 TPI
Re: Hole in Dash
Thanks. I was thinking of using this. Cut it out this size and snap it in
https://www.hawksmotorsports.com/198...er-dash-panel/
Thoughts
Old Jan 5, 2025 | 06:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Hole in Dash
If thats big enough, should work.
Old Jan 5, 2025 | 08:21 PM
pete2833's Avatar
Engine: 5.0 TPI
Re: Hole in Dash
For $20 I’ll try and see. I don’t think their dimensions are right.
Old Jan 5, 2025 | 09:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Hole in Dash
I have a bunch of those for sale. If you need more than one.
https://www.thirdgen.org/forums/inte...dl-covers.html
Old Jan 6, 2025 | 05:01 AM
pete2833's Avatar
Engine: 5.0 TPI
Re: Hole in Dash
ok. I’ll take 2. Let me know how to order and pay for them.
Old Jan 6, 2025 | 09:10 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Hole in Dash
PM sent.
Old Jan 6, 2025 | 01:31 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Hole in Dash
The OBD filler plate is a good idea to fill a hole, but any repair of that area is going to be obvious, just like the logo that was there before. Why not just put a logo back over it?
Or sticK a cell phone mount over it. Cant make it much worse by covering it with anything.
Old Jan 6, 2025 | 02:39 PM
pete2833's Avatar
Engine: 5.0 TPI
Re: Hole in Dash
I know. I’m **** about things. Can’t believe someone did that. It’s a big job to rip out the dash. Ugh.
what logo would you use ?
Old Jan 6, 2025 | 05:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Hole in Dash
The OBD filler plate is a good idea to fill a hole, but any repair of that area is going to be obvious, just like the logo that was there before. Why not just put a logo back over it.
If you mean the emblem, that's over by the pass vents. This is right under the center vents.
sodak
Apr 5, 2022 03:43 PM
82 Iron Duke
Apr 13, 2006 11:19 PM
