Parking brake handle
Old Nov 18, 2025 | 06:51 PM
dwwebste's Avatar
Car: 1984 Z28
I'm pulling out my interior and getting the center console out was a bear, due to only being able to get the parking brake handle up to about 50 degrees, where it would have been much easier if I could have taken it straight up to 90 degrees. When I start putting stuff back in, is there a way to raise the handle up higher? I didn't want to just unbolt it from the trans tunnel and risk messing something up (I live in constant fear of screwing up!) You can see in the picture how high up the handle would go.
This is the first time I've ever done an interior like this so I'm still learning.
Old Nov 20, 2025 | 09:31 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Parking brake handle
Should be easy for you,.... The Parking Brake adjustment is under the car and easy to access now that there's no drivetrain in the way. The cable that feeds thru the body and under the car has a long threaded rod at the end with a adjustable (31mm?) nut on it. Just get under there, put a small wrench (or vise grips) on squared-end of the cables threaded rod, and use a second wrench to back-of the adjustment nut.
FYI: It's best to re-adjust the brake handle once your done installing the interior and before you install the torque arm and driveshaft. Having it move to 90 degrees makes removing/installing the center consoler easier, but it doesn't actually work as well (IMO) when it's adjusted that far.
Old Nov 20, 2025 | 10:35 AM
dwwebste's Avatar
Car: 1984 Z28
I have not gotten the torque arm or driveshaft out yet (hoping to do that this weekend in the daylight) but will definitely be looking for the adjustment nuts once those are out.
I may need extra advice on getting anything else off the transmission as I pull that with the engine, so any tips and tricks would be greatly appreciated!
Old Nov 20, 2025 | 12:59 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
On my 83 Camaro the adjusting nut for the parking brake is a 12 mm.
navy02ws6
Brakes
Sep 27, 2022 11:04 AM
project305TBI
Brakes
Dec 9, 2008 09:56 AM
