A/C restoration
Old Feb 24, 2026 | 06:33 PM
Gotwood's Avatar
Car: 1986 Z28
Engine: LG4 305
Transmission: T5 manual 5 spd
A/C restoration
Excuse me of I've posted in the wrong place or missed the correct search. I'm restoring my 86 Z and it's time to get the a/c working. I'm trying to stay as stock as possible. What/ where should I be looking for a complete replacement?
Old Feb 24, 2026 | 08:33 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: A/C restoration
Classic Auto Air is where I got my complete modernized kit made for our cars. It's a new Sanden style compressor. Came with the appropriate mounting bracket, hoses, condenser and evap. I'd stay away from that big power robbing Delco unit. If you can even find one. I think they sapped something like 14HP whereas the Sanden uses 2, so I've been told. I can't even tell when mines engaged. Blows cold. I installed it in 2016 and still us it to this day. Never had to service it.
Old Feb 25, 2026 | 03:06 PM
Gotwood's Avatar
Car: 1986 Z28
Engine: LG4 305
Re: A/C restoration
It doesn't appear that they make a 3rd gen kit.
Old Feb 25, 2026 | 03:38 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: A/C restoration
The first link is 86 to 87. Second is 88 to 92. First one is exactly what I have. Says sold out but they do appear to have them. Not sure where they are now but I bought and picked mine up in Tampa
https://www.classicautoair.com/produ...nversion-kits/
Old Feb 25, 2026 | 07:37 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: A/C restoration
https://vintageair.com/pages/search/...0/Model/Camaro
Old Feb 26, 2026 | 01:06 PM
Gotwood's Avatar
Car: 1986 Z28
Engine: LG4 305
Re: A/C restoration
Both are no good. Classic Auto doesn't carry it anymore and vintage is the same.
Old Feb 26, 2026 | 03:19 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: A/C restoration
Nothing wrong with the OEM stuff. It fits and it works. You can get all of the OEM replacement components on RockAuto. With the age of the car, I would replace everything (compressor, condenser, evaporator, lines, pressure switches). Go with a little smaller orifice tube (stock is white, use the Ford red one). Add the required amount and viscocity of PAG oil based on what the compressor instructions say, pull a vacuum, charge with R134A. Use about 85% of the amount of refrigerant on the original underhood label for R12. You can also adjust the low pressure switch 3-4psi lower (adjustment screw underneath the electrical connector) to drop the evaporator temperature down to where the old R12 system would run.
Old Feb 26, 2026 | 04:28 PM
jamessmith's Avatar
Re: A/C restoration
That restoration thread is really inspiring, and it’s clear a lot of love and careful work went into bringing that interior back to life. Taking your time with each piece and using quality materials really shows in the final result. It’s also smart to document your process so others tackling similar projects can learn from what worked and what didn’t. What part of the interior did you find the most challenging to restore?
Old Mar 29, 2026 | 09:09 PM
Gotwood's Avatar
Car: 1986 Z28
Engine: LG4 305
Re: A/C restoration
Update:
I installed a complete new stock system and charged it with 134A. Cools to about 45°.I have about $900 in it. I'm happy. The evaporator is a little different and required a little extra insulation but driving on a 88° day in NC is comfortable. I didn't use the red orffice that was recommended in some forums and I wonder if that would have made a difference. All in all I'm happy. Now on to the stereo and I'll be content for the time being.
Old Mar 29, 2026 | 09:44 PM
BURD's Avatar
Re: A/C restoration
What’s wrong with yours?
Old Mar 30, 2026 | 07:30 AM
Car: '89 GTA
Engine: ZZ6TPI
Re: A/C restoration
Did you adjust the low pressure cutout switch? Take the connector off and there is an allen screw in the middle to adjust it. Lower the cut out pressure by 2psi to set the evaporator minimum temperature to be the same as it was for R12.
@32F
R12 = 30.1psi
R134A = 27.8psi
Old Apr 4, 2026 | 07:53 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: A/C restoration
Update:
So you used a new R4 compressor?
How long have you had it installed and working?
Any regrets?
Old Apr 5, 2026 | 01:51 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: A/C restoration
I’m still happy.
https://www.thirdgen.org/forums/cool...sion-here.html
Old Apr 6, 2026 | 06:37 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: A/C restoration
Originally Posted by LiquidBlue
Thanks. I replied to your post
Old Apr 7, 2026 | 05:56 PM
Thirdgen4me2's Avatar
Car: 91 Z28 / 86 Iroc
Engine: L98 / TPI 305
Transmission: 700r4 / 700r4
Axle/Gears: 3.23 / 2.77?
Re: A/C restoration
Love that color combo…we did oe for my sons a/c compressor
Old Apr 8, 2026 | 11:17 AM
BURD's Avatar
Re: A/C restoration
I got this, just restored it, I’m set now.
Old Apr 15, 2026 | 07:08 PM
Boostmaster's Avatar
Car: 1987 GTA
Engine: 5.7L tpi
Re: A/C restoration
You can rebuild the R4 compressor. I did one on my Buick years ago, still working fine.
Old Apr 17, 2026 | 12:03 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: A/C restoration
I bought the parts to do mine, but haven't pulled the trigger yet. Was thinking it might happen this winter, but my cooling system repairs have drug on way too long. A/C will have to be for another day.
puma1552
Mar 26, 2012 08:52 AM
R4][N_M4l{3R
Nov 30, 2008 08:41 AM
Faded
Apr 26, 2004 08:39 PM
didjital
Sep 26, 2002 10:54 PM
Blue502
Pacific Northwest Region
Jun 10, 2001 01:31 AM
