Best Console Lid?
Old Mar 11, 2026 | 11:13 AM
69-er's Avatar
Best Console Lid?
Has anybody bought one of these two console lids?
Hawks: HT14035760,
Camaro central: CON-175B
The prices are so different, I wonder if they are different manufacturers.
I found a thread on the one from Hawk's but it's a Firebird lid. Not sure what year. He described it as junk:
I wonder if the Camaro is just as bad.
Old Mar 11, 2026 | 12:07 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Best Console Lid?
The Hawks Camaro Lid Got A 5 Star Rating
Old Mar 11, 2026 | 12:12 PM
69-er's Avatar
I saw that. Maybe I can't compare this one to the other lid in the above post.
If I have to, I'll order both and then make a decision.
Old Mar 11, 2026 | 12:14 PM
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Hawks: HT14035760,
I have one. It's garbage. Just saw you're asking about the camaro one... can't say, but the firebird one sure is junk.
I just posted about it yesterday in another thread.
Old Mar 11, 2026 | 12:23 PM
codyman125's Avatar
Car: 1989 Firebird
Could also consider the Screaming Chicken lid.
Old Mar 11, 2026 | 01:07 PM
Turchman's Avatar
That was my post. It is a Firebird Lid, and was total junk plastic inside. I made it work using a whole tube of two component epoxy and eliminated the spring that pulls it down. I'm using a magnet to keep it from flopping. The Camaro lids you show look much better
Old Mar 11, 2026 | 02:33 PM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
There are a couple on E-Bay for 75 dollars, but their condition may not be much better than yours.
Mine was cracked as well and I just got through installing a piece of aluminum angle inside with 8-32 nutserts.
The hinge anchors were also broken.
Aluminum angle with nutsets installed using JB-Weld..
When I was done I used fabric paint to dress it up.
I will have to see if it holds up?
Old Mar 12, 2026 | 09:55 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
Thank you! The Camaro lid we sell is American made and has been a popular product over the last couple of years (current price is $89.95). Unfortunately, we have not found a quality Firebird console lid that we feel comfortable selling.
1982-92 Camaro Padded Center Console Lid – Screaming Chicken
Old Mar 12, 2026 | 08:45 PM
69-er's Avatar
Dang! I placed a large order yesterday with Camaro Central including their lid for $135. Maybe I'll be able to figure out the manufacturer and see if it's the same as yours.
Old Mar 12, 2026 | 08:57 PM
scfbody's Avatar
$89.95 is the regular price on the one we sell. It used to be $149 about two years ago but the manufacturer switched to a US based factory and the price went down quite a bit. I believe there is only one company making those and then they go to the different retailers like Screaming Chicken, Hawks, Camaro Central, Classic Industries, Summit, etc.
Old Mar 25, 2026 | 09:44 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've bought several things the past three years from Screaming Chicken and have been quite happy.
Old Mar 25, 2026 | 10:18 AM
69-er's Avatar
I forgot to follow through with this. I received the lid from Camaro Central and it looks great. There were no other identifying numbers on the package, but I would assume it's the the same as Screaming Chicken's.
The only issue I see is that the latch doesn't appear to want to move in far enough to clear the striker and makes it difficult, if not impossible to unlatch. I didn't have the hinges bolted to the console, so I can't be sure what the problem might be if there is any. My first thought is to trim the length of the latch, but we'll see when it's time for final assembly.
I considered returning it to get Screaming Chicken's but after the restocking fee, return shipping and time spent, I'll just keep it.
Old Mar 25, 2026 | 10:25 AM
scfbody's Avatar
We have not had the latch problem with the one we're selling. I'd bolt it up and see if that helps.
Old Mar 25, 2026 | 11:00 AM
69-er's Avatar
Yeah, I bet it had a lot to do with me trying it without installing it. (I hope)...
Old Mar 25, 2026 | 11:30 AM
69-er's Avatar
Well now, maybe I will be return this lid. I discovered two cracks on the underside plastic by the one of the latch screws. Maybe it was over-tightened.
We'll see what they say.
Old Mar 25, 2026 | 11:48 AM
scfbody's Avatar
I'm going to take some additional pictures of the part we sell, may not be the same part.
Old Mar 25, 2026 | 12:10 PM
69-er's Avatar
Yes, please share them. I'll upload some to compare.
Old Mar 25, 2026 | 08:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Fixed/reinforced mine by drilling holes, installing a steel rod, stitched the cracks together with copper wire and oatey black goop. Steel plate opposite arm w/ matching holes for rivets. Rebuilt pad w/ expanding foam . Been good since 2014.
Old Mar 26, 2026 | 09:09 AM
BURD's Avatar
How much is a nOS lid?
srosscamaro@aol
Feb 14, 2022 07:45 PM
srosscamaro@aol
Jun 13, 2021 03:50 PM
myk82
Oct 11, 2017 01:40 PM
fast83camaro
Jul 26, 2001 06:19 PM
