So i dropped my car off at ThirdGenResource Today.......
Old Mar 15, 2004 | 09:19 PM
  #351
polishdevil's Avatar
Car: 88 GTA
I applaud (sp?) you for staying with a 3rd gen and making it the way you want. After my gta got totalled last year, i got the vette and it was fun...i miss my gta now and kinda regret buyin the vette. I'm as anti **** as people get and i think your wing sets the car off just right. Good luck with the car i can't wait to see some time slips.
:hail:
- You'll be running 12's for $10K while i run 14's with a 93 vette
Old Mar 16, 2004 | 12:57 AM
  #352
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Flow, you seem to be a good person but I go against quite a bit with your tastes.
I dont see the logic in what you do with your car, but its your car. I dont see the logic in building a drag car out of a honda but people do it. Some run way better then I'll ever run with my setup, but some are stuck in the 12's trying to figure out why there manual tranny FWD car either brakes axles or doesnt hook...
I will have pictures within a couple days, I actually just got the engine running tonight, still working out some stuff.
Vortec heads, XE274, Holley 750dp, Performer RPM, Hooker LT's.
Similar setups are around 400fwhp. To give you a rough guesstimate, my buddies Z-28 with a 406sbc, heads worked a bit, custom grind Solid Roller, 850DP, exhaust is 11.30's on street tires. Im not making quite as much power as that beast, but I know I have the power for low 12s with my heavy *** car, if not 11's.
I have other issues though, like the 30 year old saginaw 4 speed, and the clutch, and the couple oil leaks, and the blue smoke and and and the, hopefully you will not have these problems.
One thing about my car though, is it is by far more fun then my 3rd gen. Everyone asks questions, revs, thumbs up, compliments, EVERYTHING. The thing sounds like a mild drag car, what can you expect from barely any exhaust and a slit one of the mufflers has a hole in it the size of a basketball.
Old Mar 16, 2004 | 01:07 AM
  #353
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Flynlow-
Ive been off the boards for a while. Did you get your car back yet? Or how long till its done? Also i wanted to know if ou had any pics of that 4th gen gas tank setup. I was thinkin about going that route.
Old Mar 17, 2004 | 09:34 AM
  #354
jdrafke's Avatar
Just a suggestion, i noticed u said u werent gonna be putting a cam in the motor to retain drivability and stock like qualities. You could look into the new stealth cams for the ls1. i hear they obtain stock like idle and gas milage(if u have a light foot) but have amny people running 11.30s on drag radials :hail: The only prob is u need some good springs and retainers. Juicing it may be good but to have the power there all the time i think is better. Plus, those times are with autos who knows with a manual.
Old Mar 17, 2004 | 09:36 AM
  #355
jdrafke's Avatar
Sorry thats also with ported heads. But people on the ls1tech board i have seen run 11.60s with stock ls1 heads. May want to get ur hands on the ls6 intake. I hear its better for the reverse split of the cam. But i am by far a genius on the topic just throwing out ideas. 11s with stock like idle and gas!!!!! Amazing
Old Mar 18, 2004 | 09:38 PM
  #356
FLYNLOW92rs's Avatar
Nope, haven't picked up the car yet.....
Leaving 1 week from today to go pick it up.......:lala: :lala: :lala:.......Roy will have it done by Tuesday......
I will get under the car and take pictures of that 4th Gen gas tank, as i know there is no information on it available, hell i don't even know how he got it to work, but i'll ask the questions when i get there........
Old Mar 18, 2004 | 10:02 PM
  #357
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Theres a free tank of gas in it for you if i can take 'er for a spin...*nudge nudge* :hail:
Old Mar 18, 2004 | 10:54 PM
  #358
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Did you get rid of your old driveline?
Did he say what he is doing to it in this last week?
Old Mar 19, 2004 | 07:37 AM
  #359
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
Hey Flynlow, I was wondering how much it cost you just for the LS1, no labor or anything. I am curious becasue I would love to do the swap and just want to know how much a good LS1 runs. thanks
Old Mar 19, 2004 | 09:24 AM
  #360
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
If you shop around, you can find them anywhere from 2K-4500, depending on mileage and what is included in the package (i.e. engine+tranny) If you are doing a LS1 and t56 swap, you can usually find them for under 5K together, and in some cases around 3500 if, like I said, you shop around.
Old Mar 19, 2004 | 09:27 AM
  #361
camaro05's Avatar
Car: 91 Z28
thanks, that is about what I have been seeing on ebay. I don't plan on buying one from there but I just want to see what I should expect to pay for one.
Old Mar 19, 2004 | 07:24 PM
  #362
The old drivetrain is sitting at thirdgenresource.........No plans for it yet......
The exahust work needs to be completed outside of his shop, so it's going there.....
Custom headers to a SLP Loudmouth Dual Exhaust......(changed the plans a bit)
Old Mar 20, 2004 | 07:57 AM
  #363
nolanr0413's Avatar
Car: Trans am
thats gonna be awesome when we get to see it and hear some ets.
Old Mar 24, 2004 | 11:40 AM
  #364
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
FLYN'
I ahve always loved your car...wing and all. I'm not sure of the production numbers but sems like there were 42 billion million thirdgens made. Anything done to set them apart is good. I really like the side vents and want to do something like that to mine.
I hope the LS1 swap goes well. My future plans may include something like that! For now I ahve to deal with my LO3. Anyhow good job. wish I lived closer to FL. so I could drop by and drool. Any chance you might be able to make to THIRDGENFEST. in Ill. That would be a sweet time for a premier.
Don't let these guys give you a hard time for what your doing, believe me I love working on my car, but if I had the $$$ I'ld let somebody else have the headache of a complete swap like that.
One question about your door handles, what did you do about the door panels and you interior?
Scoty
Old Mar 24, 2004 | 03:47 PM
  #365
:lala: :lala: :lala: :lala: :lala: :lala: :lala: :lala:
Attached Thumbnails So i dropped my car off at ThirdGenResource Today.......-sams-92rs-ls1-c.jpg
Old Mar 24, 2004 | 03:51 PM
  #366
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
/me dies of jealousy.
Old Mar 24, 2004 | 03:59 PM
  #367
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
<--------- weeps at the sure beauty of the thing
Old Mar 24, 2004 | 04:20 PM
  #368
Pearl Jammzz's Avatar
Car: 89' RS
Engine: 2.8 V6
So that's the y-shaped LS1? the ones out of the vettes?
DYNO IT! I know we ALL wanna know what u are puttin to the wheels w/ that.
Old Mar 24, 2004 | 05:01 PM
  #369
Kandied91z's Avatar
was anything modded to that engine? i'm going out on a limb and saying 3-310 at the wheels. looks great!
need to get the filter lower to the ground though as your not getting much air flow there and the air your getting will be hot. keep up the good work...
Old Mar 24, 2004 | 07:40 PM
  #370
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
OOOOOHHHHHHHHH! Looks great. Cant wait to get mine in. Just waiting on the motor and tranny mounts.
I think I might be using those vette covers also. I wasnt at first, but they look pretty good sitting there on your motor.
Also, do you know what throttle cable they used on your setup?
Old Mar 24, 2004 | 08:30 PM
  #371
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
:hail:
Old Mar 24, 2004 | 09:28 PM
  #372
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I would think about upgrading to dual fans.
Looks great, congrats.
Old Mar 24, 2004 | 09:30 PM
  #373
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
wow man u did it, u got the power to back up the looks like u always wanted!! congrats!! $hit i bet u cant wate to go to a meet were no one know your car and u pop your hood lol.
i am so jealous of u i luv everything about your car except the colour. just make sure u make lots and lots of videos and post them all! oh and dont tell people what u have under the hood untill u beat them lol.
later!
Old Mar 24, 2004 | 10:39 PM
  #374
kevinc's Avatar
Car: 1982 Z28
Looks like he's close to having it running...radiator cap's still off, no coolant reservoir, no main serp belt.
I need to pop a set of Corvette covers on mine, that looks great.
I like how he did the battery 12VDC main junction on the passenger side strut tower panel. Won't let you mount a strut tower brace there, but it's a nice way to handle that. I snagged an LT1 2-pole box and did this on the driver side fender:
http://www.warpten.com/carpics/ls1_0214/DSC00041.JPG
The wire is bundled up in conduit and routed correctly now, fuel lines are secured and routed right also.
Old Mar 25, 2004 | 02:55 PM
  #375
That's the box for my underbody neon lights......
It's comming off and moving elsewhere so i can run a Kenny Brown STB
Old Mar 25, 2004 | 03:21 PM
  #376
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
That is EXACTLY what I have in mind for my car!! well, other than the magical twin turbos that will suddenly appear on the car from the invisible man.... I'm glad someone was able to get it all done. Now I'm gonna have a really hard time deciding to keep the A/C or not, w/ that new compressor bracket. BTW, any info on the 99+ plastic gas tank?? what needed to be changed/ additional cost??
Old Mar 25, 2004 | 09:59 PM
  #377
kevinc's Avatar
Car: 1982 Z28
...underbody neon lights...
Old Mar 27, 2004 | 01:51 AM
  #378
dirt's Avatar
Car: 1987 RED RS
Engine: 2.8l
Transmission: auto
nice car, very nice.
Old Mar 27, 2004 | 02:16 AM
  #379
Kandied91z's Avatar
no reason for that....
Old Mar 27, 2004 | 03:10 AM
  #380
theSteve's Avatar
Car: 1985 Trans Am
Old Jul 8, 2010 | 07:13 PM
  #381
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: So i dropped my car off at ThirdGenResource Today.......
yes i know its an old thread, but lets see the finish product.?
Old Jul 8, 2010 | 09:22 PM
  #382
Scooby's Avatar
Car: 1990 Camaro
Engine: 305 TBI
Car was totalled in a wreck but it was a beast
Old Jul 8, 2010 | 10:35 PM
  #383
Mailman's Avatar
Ugh. Read all 8 pages to find out it was totaled. I want my 15 minutes back.
Old Jul 9, 2010 | 12:04 AM
  #384
Engine: 305TPI
not to sound lazy, but how was it totaled, i read the first few pages and the last and i didnt see anything about it being totaled.
Old Jul 9, 2010 | 12:14 PM
  #385
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
If memory serves, it went on fire.
Old Jul 9, 2010 | 02:43 PM
  #386
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
YUP
Old Jul 9, 2010 | 03:12 PM
  #387
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Easily done with a swap. I recently sold my LS1 and even though i am UBER careful with wiring/heat shrinks/harness tape etc etc etc. I had two wires that were rubbed through the heat shrinks bare. They werent anything that could set the car on fire the were only sensor wires where they were going through the firewall PLUS they were still inside the loom and wrapped in harness tape but still... I was banking on those heat shrinks to be tougher than that.
Considering all the wiring needing done on an LSx swaps scale just a word to anyone who reads this to be EXTREMELY careful with your wiring.
Especially fuel system wiring and fuel lines too. Dont cheap out and use rubber everywhere. Use aeroquip if you need flex otherwise hardlines are the ticket. Stay away from cheap compression fittings as well.
Rant over and a sad recollection of FLYINLOW's car. He was one of the very first LSx swappers on these boards if not the first
RIP 92
Build another one but do it yourself this time LOL
Old Jul 9, 2010 | 05:51 PM
  #388
Pocket's Avatar
Car: 91 Trans Am
Thought he needed the money and parted it out? Maybe Im thinking of a different gorgeous green RS from the classifieds
Ghettobird52
Jul 5, 2024 11:18 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
bryan623
Aug 10, 2015 11:33 AM
Kaweh
Aug 9, 2015 02:54 PM
