So I weighed my car today...
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
I took the car to get weighed today and I was pretty pleased with it, pretty much what I expected. It was 3420 with me in it and 3300 without me. Now mind you this is a full weight no weight reduction car (except tubular suspension stuff) I have about ~50-60 lb 12" subs and box and amp that I can take out, spare tire and jack, and AC compressor that is sitting there doing nothing. If I take all that out I think i can get to 3200 without me fairly easily. What do you guys think?
UPDATED BELOW!
UPDATED BELOW!
Originally posted by Firebat
i think you'd be closer to 3100 without you in it.
3100 with weight reductions. your subs and amp wiegh 100 lbs at least
Well I took the subs and amp and box out, and I took out the spare tire (there was no jack for some reason, making the tire pretty useless), and I tried to take out the AC compressor but I couldnt because when I uplugged it the car died out when I turned on the lights
. Anyway I reweighed it and it was 3360 with me and 3230 without me. If I wanted to go a little more hardcore and start removin seats and stuff like that for the track I might be able to get it down below 3200 without me in it.
. Anyway I reweighed it and it was 3360 with me and 3230 without me. If I wanted to go a little more hardcore and start removin seats and stuff like that for the track I might be able to get it down below 3200 without me in it. Trending Topics
Originally posted by C Murda
how much gas was in the car when it was weighed?
Originally posted by STRIFE69
If the site I was just at is correct Gallon of gas can range between 5.8 to 6.5lbs. Water 8.33lbs a gallon.
Car: 2011 Ranger
Engine: 2.3L
Transmission: Stick - Shift like a man!
So I ended up using my buddies jack instead when I had a flat tire.Don't forget carpet and such either. This site says about 50lbs just for that, I think it was 18lbs for each front seat, 30 for the whole back seat.
Originally posted by jrmaatta
Funny that you say there was no jack in it. I had an 87 Firebird base model, donut, but no jack
you're still doing much better than the stock 4th gen LS1's. The stock 02 trans am wieghs 3500-3600 lbs, no driver.
damn mine weight is 3400 with out me in it. thats lt1 swap with 2 10's and amp. no ac stuff at all. and rear tire and jack. how much with out the tire and jack do u think. i might have to remove that stuff before i go back to the track.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
lt-1 is also heavier then the ls-1, intake and block alone has to be a big differance
Car: 2011 Ranger
Engine: 2.3L
Linson
Aug 21, 2015 02:12 PM
