View Poll Results: route the harness
through the fender
0%
through the firewall
100.00%
Voters: 5. You may not vote on this poll
harness location
Old Feb 10, 2006 | 08:23 PM
Kandied91z's Avatar
harness location
well i'm redoing the 91 and i'm trying to clean up the harness. i had it running the traditional way through the fender but i'm thinking about cutting a small hole under the heater box and feeding it through. sealing it properly with a gromet the harness should look cleaner.
any thing i should worry about cutting a hole in the firewall under the heater box?
Old Feb 10, 2006 | 11:15 PM
z28evans's Avatar
Car: 89 iroc
I'm putting mine under the heater box as well, i should have it finished this weekend - i'll try to post pics. Finding a gromet has been hard, i'll be making one out of some Lowe's hardware stuff.
james
Old Feb 11, 2006 | 10:07 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
I have mine going through the firewall, looks real clean. Not to hard to do, just measure, measure, measure, then drill.
Justin
Old Feb 14, 2006 | 10:22 PM
Kandied91z's Avatar
do you have a picture justin?
oddiez@hotmail.com
i'm thinking directly under the heater box to the lower right if your looking head on.
Old Feb 14, 2006 | 10:50 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
I'm sorry i don thave a pic of it when i did it (comp crashed and lost all my pics of my swap), but i know mr. dude has a good pic that he sent me when i was asking about it. Try asking him if he still has it, i made my hole just above the frame rail and just below the heater box. You basicly have just enough room to fit a 2 inch hole in that spot(i had maybe a 1/16th of an inch above and below the hole i cut.
Hope this helps, if you have anything just ask.
Justin
Old Feb 14, 2006 | 10:51 PM
5.0Camaro's Avatar
oh by the way what part of MI you from.
Old Feb 16, 2006 | 01:24 AM
Kandied91z's Avatar
we are neighbors in a sense..
Old Feb 17, 2006 | 03:30 PM
silverta8702's Avatar
i put my harness through the fire wall and took the side carpet panel off mounted the coputer to the kickpanel then used a heat gun on the back of the carpeted panel and moulded the extra shape of the computer , . looks almost factory , the only mod is to trim the top underdash panel a bit.
skeltor
Feb 2, 2016 10:37 AM
Jlanz55
Sep 6, 2015 02:35 PM
Billy Decker
Sep 4, 2015 03:46 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
tonys91rs
Sep 2, 2015 07:07 PM
