ls1 swappers check this out.
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
alright so you got your ls1 and your buying all the stuff you need for you swap right. fuel delivery you buy a afpr and run some crazy lines right?
why not go a cheaper rought. ls1 from like 99+ are non return style well keep it that way. buy a corvetter fuel filter it has 2 inlets and 1 outlet. one inlet for the feed and the other for the return line. and 1outlet for the fuel rail. now u just need to hook up your fuel filter and your line to the fuel rail. you dont need a afpr unless ur making some crazy hp. there is a fuel pressure regulator on the fuel rail.
hopefully i will of saved you guys some money if you do it this way. i know i saved myself about 200-300 bucks.
let me know what you think about this idea!
Sounds great! That's why many of us have done it that way
...could buy an ls1 gas tank and not need the corvette regulator (or upgrading the fuel pump).
for pics and a write up (there are posts by others as well):
https://www.thirdgen.org/forums/ltx-...k-plastic.html
James
~1050 miles in the last 2 weeks on my swap, and loving it
James
Car: 1987 Porsche 944
Engine: 98 LS1
Transmission: 5 speed porsche transaxle
A 97 corvette has a fuel rail with a feed and return line and thats where the regulator is, right where the dampener is on yours.
let me break this down
the cheap way...
-buy a 97 corvette fuel rail, as it has the feed, return, and regulator on the rail. 150$
the cheaper way
-buy a 99-04 corvetted fuel fileter with built in regulator and use your fuel rail with the dampener on it. 40$
either way works just as good,
and heres another hint,
hinsonsupercars.com have the quick connect to an converter for your rails!!! so no more welding aluminum or using clams
hope that helped you guys, i registered just to post this, but it looks like i can find some good info on here so thanks!
good luck on all your swaps
oh and also its 98+ Fbodies and vettes that have the returnless fuel rail. the 97 was the only year with the return line and the regulator on the rail
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im also running a corvette filter/regulator mounted where the stock filter was...
edit:
attached is a pic of my lines.... the lines on the right connect to the stock 91 gas tank lines, and clicks onto the filter/regulator.. the hardline on the left clicks right into the filter/regulator, runs up the frame like stock (it is the stock line..just modded) and ends near the prop valve on the frame rail... a OEM style nylon fuel line with quick connects at each end connect between it and the fuel rail.. exactly like stock genIII+ motors.
edit:
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Just use the 4th gen fuel T. Just need one line from your motor to the T and your set. Return line goes to the T back to fuel tank. Problem slove!
Car: 91 Camaro Vert
because the reason that works, is that the regulator is inside the tank.
so you can either run the 4thgen tank, and do that, or drop a walbro in your existing tank, and hookup the filter regulator....or drop in a walbro hookup a FPR up front with one line going to the fuel rails..
all of them work just fine... pros and cons to each.
Car: Camaro RS/SS
Engine: 5.7 LS1
No I meant Fuel T. I would post a pic but it wont let me. Says that i already did in another thread. But yeah Fuel T.
Car: 91 Camaro Vert
uhh, ok, that works great if you have a 4thgen tank... because then the regulator is in that "return" line from the T.. (technically, that isnt really a return line, just a feed to the regulator)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: Camaro RS/SS
Engine: 5.7 LS1
I have an idea that a buddy gave me in order to use my 3rdgen lines and also use the quick connects going to the fuel rail. Im not done yet with it but i will post up when its done. Going to look like factory when its all done
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I used the f-body kit and the stock thirdgen tank with a walbro, seems to work well
