VATS Bypass Module
Old Apr 25, 2006 | 11:37 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
VATS Bypass Module
I have used 5 of the bakerelectronics bypass modules off of ebay. They have always worked great and have never been disappointed, if you need a bypass module for vats get one from them. You will not be disappioned and they are only 29.95 shipped. Ordered mine on thursday afternoon and it was here on monday. Anyway it is an alternative to having the pcm reprogramed .
Old Apr 26, 2006 | 09:30 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Programmed out of the PCM, no need for a vats bypass
Old Apr 26, 2006 | 03:36 PM
TexasLT1's Avatar
Car: '92 RS
but if you need to have the PCM programmed anyway for something else, have it programmed out and save $30 and the time it takes to wire it in.
Old Apr 27, 2006 | 07:31 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I would get the bypass box and wire it in with a connector. Put it where its easy to get to so you can take it in and out. This way if you're ever in a big city or somewhere not familiar, you can take it out and have piece of mind that your car will still be there when you return to it. Just an idea.
Old Apr 27, 2006 | 09:13 PM
beedo's Avatar
I agree with you as far as having it programed out, but I didnt have the software and wasnt going to spend the money to have a few things programed out just to get it running. going to tune it myself and get all the other bs out of the pcm when I am able to get the funds up. Good idea stngklr.
Old Apr 27, 2006 | 09:35 PM
Klortho's Avatar
Car: 1987 GTA
I guess that's just the things of living in a small town. Largest city my car will ever see is probably Bristol or Nashville. However, my car never had VATS on it, so I just took it out.
Besides, if they want the car, they'll figure a way to get it.
Old Jun 15, 2006 | 11:24 AM
GM-LSX's Avatar
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
If your Car has VATS (like my 91 Firebird). Can't you program the PCM to the the resistor in the Key or order a NEW Key which fits to the Resistor Value in the PCM?
If NO
Why?
Old Jun 15, 2006 | 11:41 AM
beedo's Avatar
When doing swaps you dont have any way to find out the resistance of the key if you dont have it. I put in a 97 pcm which runs the vats throught the BCM not the vats module. You can have the VATS turned off in the pcm but you cant program the the pcm for a specific key. The PCM looks for a square wave signal from the VATS module to keep the fuel coming.
Old Jun 15, 2006 | 12:28 PM
GM-LSX's Avatar
So IF you got the original Key, you can measure the resistor and order a new Key for your existing lock with another, matching resistor in it?
And if you don't have the original Key. Can't you do trial and error with the 15 differed values? As far as i know there are 15 different resistor values combined with the individual keyprofile on the Passkey I system. The same on Passkey II plus a delay of several minutes if the resistor-values don't match. Or is there something i miss
Old Jun 16, 2006 | 01:03 AM
beedo's Avatar
Got me, I really dont dont if the vats module will work with the newer pcm or not. I spent 25.00 and about 2 minutes wiring it and was done, I was to the point where all I wanted to do was finish running wires and be DONE. In my opinion the money is well worth it in the time and headache spent trying to figure out what resistor to use and if it will work. I have read alot of posts on here and I havent seen anything about it.
Old Jun 18, 2006 | 10:46 PM
ShawnPennington's Avatar
Car: 84 z28, 86 firebird, 91 camaro RS
Engine: 84 350,86 V6,91 305
Wish i could do that lol i just bought a 91 Rs camaro and it has the VATs system in it.. what i didnt know is that the lady that i got the car form had lost the key. so im stuck tring to find someone dealership or anyone that can get the code or a way around it without knowing the resistance.
Old Jun 19, 2006 | 03:08 AM
GM-LSX's Avatar
Hmm.... Speeking of Dealerships: How about flashing the whole PCM with the Tech2? If they do this to a stock Car they got to get the anti theft system to work also. Same when they replace a faulty one.
Old Jun 19, 2006 | 04:56 AM
GM-LSX's Avatar
Now this sounds like most Engine Swaps are just incomplete:
http://www.usautomotive.co.uk/tech/Anti-theft.asp
http://www.motorage.com/motorage/dat...09/article.pdf
Old Jun 27, 2006 | 08:45 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
beedo, could you please explain the installation of the bypass module, since you've done it yourself ?
Old Oct 19, 2006 | 01:12 PM
RS_Camaro_78666's Avatar
Do you have a link (or item number) to where i can find this bypass module? I am searching e-bay now and im not having any luck locating it. Thanks.
Old Oct 19, 2006 | 10:47 PM
1991rs1971's Avatar
Here you go...I dont have any association with this product.
eBay Motors: GM VATS or PASSkey II Bypass Module For LS1 and LT1 (item 220014050176 end time Nov-02-06 11:17:57 PST)
Old Nov 17, 2006 | 01:43 AM
ledzep2006's Avatar
hey get back to me on that (vats) cause im gettin a 90 camaro rs
but its that damm vats **** won't let it start
i need to how to work it live in san antonio
check out my car (ledzep2006)
Old Nov 18, 2006 | 12:06 PM
1991rs1971's Avatar
here is some info on it.. http://www.12vp.com/info_resistors.htm
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
