Shifter Location Woes :(
Old May 7, 2006 | 11:17 AM
dingle's Avatar
Car: '83 Camaro
Has anyone else had a problem with the location of their shifter? I just got my car back from the shop and I'm thinking they did a real ****ty job installing the LS1 and T56. I got the motor mounts and crossmember from Hawks (only ones who offered them in black). The shifter is so far to the right that I can't put the boot on.
dingle
Old May 7, 2006 | 01:53 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
spohn strikes again..
can u even get the car into reverse?
id suggest takin the console out and the rubber protecting boot and having a look to see if its centered in the tunnel
Old May 7, 2006 | 05:56 PM
dingle's Avatar
Car: '83 Camaro
5th, 6th, and R can only be used when the shifter cover plate and boot are not on but it will go in. I took a look under the car and the tranny is bolted into the middle hole but there is a hole to the left and right of it. How exact does the lineup of the tranny to the axel have to be? In other words, can I move the tranny over the the left hole to make more room?
The did have to cut some of the tunnel to get it in there since its so far right.
Do they make shifters that are bent to the side? Lol
Old May 7, 2006 | 08:04 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
My Spohn crossmember worked like a charm, but I also cut the hole in myself.
Was the car originally a 5-speed or automatic?
Old May 7, 2006 | 08:57 PM
TexasLT1's Avatar
Car: '92 RS
when I installed my T-56 the stock lower boot gets stretched pretty good in 5th, 6th, and reverse, and the shifter contacts the console just a bit, but nothing too major. not sure why yours would be so far over.
Old May 7, 2006 | 09:00 PM
dingle's Avatar
Car: '83 Camaro
5 speed. My dad suggested I get some longer bolts and put a aluminum spacer in there to move it over. where it's at is not going to work, short of moving the transmission over a hole I don't know what else I can do.
Old May 7, 2006 | 09:19 PM
Klortho's Avatar
Car: 1987 GTA
It's very possible they put the tranny in the wrong hole on the crossmember. I believe I have mine in the far left hole and it lined up perfect.
As for the boot stretching, it did until I put the Hurst shifter on, now it isn't stretched at all in any gear.
I went back and read, you ment the rubber boot on the bottom, I used a 6-speed boot from a 4th gen that goes to the tranny tunnel.
Old May 8, 2006 | 07:17 AM
dingle's Avatar
Car: '83 Camaro
Ah well I am definitely not in the far left hole. As for the boot, I was refering to the leather cover for the shifter, not the rubber boot. Is the rubber boot supposed to come up over the bottom of the shifter all the way to the bolts? Mine is basically bunched up around the big base of the shifter.
Old May 9, 2006 | 06:02 PM
THIRD GEN 92's Avatar
Car: 92 Camaro Rs Ls1 converted
Engine: Ls1 346
Transmission: t56
Axle/Gears: Moser/4:10's
dingle
Me and my friend had the same problem in his car so we made a off set braket of 3/16'' flatbar and it fixed the problem.
Old May 11, 2006 | 12:01 PM
RAGEman's Avatar
Car: 87 Camaro Z28
Yes, I have the exact same problem w/ my T-56. I also used the Spohn crossmember. Under the car, my tranny goes through the furthest hole on the passenger side. If you look at you shifter stick tho, it is perfectly center with the car, but the E-brake set-up is a little diffent on our cars than 4th Gen.
Old May 11, 2006 | 12:52 PM
dingle's Avatar
Car: '83 Camaro
Strange, Klortho said his was in the far left hole (drivers side), mine is in the middle and yours is on the far right (passenger's side)? I would think the angle of the axel to the rearend should be the same for all of us, yet we are all using different mounting holes? Was there any worry of binding on the axel for you Klortho? That is all that is holding me back from moving it to the drivers side hole.
Old May 11, 2006 | 12:56 PM
91Z28-350's Avatar
i use the middle hole on mine and it seems fine.
Old May 11, 2006 | 01:33 PM
dingle's Avatar
Car: '83 Camaro
There must be a difference in the engine mounts then. Where did you guys get yours from?
Old May 11, 2006 | 04:29 PM
TexasLT1's Avatar
Car: '92 RS
if everything else lines up, I would do as RAGE suggested and offset the shifter.
by the way, you the same dingle thats posting on LS2 about an LS1 swap?
Old May 11, 2006 | 06:38 PM
dingle's Avatar
Car: '83 Camaro
Yea, I am going to stop at lowes an get some washers to try that out and if it works ok I will get some solid cut aluminim.
And yes, yes I am.
Old May 11, 2006 | 08:54 PM
Klortho's Avatar
Car: 1987 GTA
Well, mine is an LT1 so it used the same mounts that a standard 350 would use instead of the LS1 conversion mounts.
Old May 12, 2006 | 07:25 AM
RAGEman's Avatar
Car: 87 Camaro Z28
I have an LT1 as well, but shifter is in the exact same location as yours. I would not force it into any other hole than it is intended to be in, that may cause more problems. I think yours is sitting right because as I said, if you look at the console as a whole, the shifter is sitting dead center, just the E-brake takes up the right side half.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
topteam54
Oct 6, 2015 12:21 AM
david068513
Sep 18, 2015 10:36 AM
MarineIROC
Southern California Area
Sep 16, 2015 05:40 PM
tonys91rs
Sep 2, 2015 07:07 PM
