91 Z28, LS1 Swap Finally Runs, video inside
Old Jun 13, 2006 | 02:17 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Thanks to everyone on here that has helped me out, I finally had time to go out and take a little video of the car, hope you enjoy 8)
Click Here to see the video
Old Jun 13, 2006 | 11:51 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
CONGRATS!!!!! That must be the best feeling in the world!!! cant wait to have that feeling too Sounds really good. I bet it even sounds even better in person. AWESOME!!
Old Jun 13, 2006 | 11:26 PM
StevenK's Avatar
Car: 91 Z28
Ohh yeah, its hard to capture because its sooo loud.
Old Jun 13, 2006 | 11:45 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I bet it is.. Hes peeled from ear to ear LOL Thats truly amazing. I will have that grin when i do my turbo lq9 6.0L swap
Old Jun 14, 2006 | 12:13 AM
Red92RS's Avatar
Car: 1992 Camaro RS
Great job Steven, hopefully mine will be running soon.
Old Jun 14, 2006 | 12:24 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Welcome to the club.... the upgrades will never stop.
Old Jun 14, 2006 | 08:35 AM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
That is one sweet car! Congrats man, Mine will be at that point soon
Old Jun 14, 2006 | 10:58 PM
StevenK's Avatar
Car: 91 Z28
There will be no more upgrades for awhile, getting it on the road is #1 priority now.
but when the upgrade bug does hit me, it will most likely be a LS6 intake, new MAF, and maaaaybe a 100shot
Old Jun 15, 2006 | 10:30 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
good to hear steven, i know you have been fighting it for a while
Old Jun 17, 2006 | 12:35 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Nice looking car there Steven. Welcome to the club.
I had that same cam brand new in a box for a year and a half and never installed it. I think I was too scared to do the cam swap myself. Instead I sold it on LS1tech to a guy who got 60hp out of it. I kick myself in the *** everyday.
Happy burnouts to ya.
Old Jun 18, 2006 | 01:24 AM
StevenK's Avatar
Car: 91 Z28
The cam swap was easy since I did it with the motor out. If I had seen it earlier, I would have got the 2 peice timing chain cover that I saw in the back of a chevy mag, makes it so you can do a cam swap without pulling the front balancer, which was a PITA.
Old Jun 19, 2006 | 03:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
StngKlr:
cam swaps are insanely easy on LS1s... easiest motor ive ever worked on. and with the rubber/shim gaskets, they dont leak either... go buy yourself another cam, some 918s, and some hardened pushrods...
Old Jun 19, 2006 | 07:59 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Originally Posted by MrDude_1
StngKlr:
You guys are making me feel better about it. J/K lol.
Yeah I read and heard that it was super easy to do, but just never did it. Then the time came where I was jobless for a few weeks and needed some cash so... It was an entire cam kit also, 918 springs, pushrods, cam and gaskets. Let it go for $500. I'm currently looking for another one though. I still need something better than a 2.73 gear also, looking into that too.
Old Jun 21, 2006 | 04:09 AM
StevenK's Avatar
Car: 91 Z28
Little update, I started it up and tried to put it into gear, grind grind. So I put it in reverse and started it up, it started, and then started to roll back with the clutch fully in, so I hit the brake to stop it, clutch still in, and the car stopped and so did the motor.
So the clutch isn't disengaging all the way. Its not 100 locked up or the car would have started rolling as soon as I hit the starter.....
Old Jun 24, 2006 | 10:01 PM
Red92RS's Avatar
Car: 1992 Camaro RS
I just heard my car start for the first time today through open long tubes , and steven they have modified my spohn crossmember to clear the exhaust and i will try to get pics up sometime in the next few weeks. I would like to thank xtremeirocz and ARD(Advanced Racing Dynamics) for the hard work and long hours they have put into my swap
Old Jun 24, 2006 | 10:29 PM
StevenK's Avatar
Car: 91 Z28
Yeah, those open headers sure are loud arnt they.
Yeah definitly post some pics, I'd like to see what they did.
You know, I got the K-member, and now Spohn makes them. I got the X-member and now they have changed them....
....Seems I did my swap a year early, cause I'm getting the short end of the stick on all these parts, K-member fit sucks, and now a better X-member
I guess it will all be ok once I get to drive my car again.
Old Jun 25, 2006 | 01:35 PM
Red92RS's Avatar
Car: 1992 Camaro RS
Just to make sure there is no confusion, the shop(ARD) working on my car modified spohns crosssmember not spohn.
Old Jun 25, 2006 | 09:54 PM
ChrisH821's Avatar
Car: 88 sport coupe
About your clutch issue... you probably used a 98-02 pedal assembly thinking it would work as bolted in, I know I did. But it isnt so... I had to move the point where the master cylinder attatches to the pedal down just a little bit so that it would fully compress the master cylinder. I grinded the back of the pressed in peice, pressed it out and then welded it back on. Made me wonder why I bought the ls1 pedal assembly. Oh btw yeah perma-grin is a good way to put it here is a pic from my cell phone camera hope this helps.
Attached Thumbnails 91 Z28, LS1 Swap Finally Runs, video inside-25-05-06_1609.jpg
Old Jun 25, 2006 | 10:29 PM
StevenK's Avatar
Car: 91 Z28
I just fixxed that problem by moving my master cylinder up to remove the play from the pedal....hehe
I actually drove the car out of the garage under its own power today and washed it, it was exciting to say the least. And I hooked up the laptop so I could see the tach and gave it a little pedal, I'm gonna need some good mufflers to tame this monster sound!
Old Jun 27, 2006 | 10:40 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Sweet, glad to hear one up and running!! Can't wait form mine to fire up, seems like its going to be forever though. The wiring is what scares me the most at this piont.
Anybody know if thirdgen pedals will work?? My car was an L98/700R4, so I have gotten a clutch/brake pedal set and I think the slave cyl was on there too. It's been a while since I actually looked at it, hmm.. I'll have to compare it to what's on the T56. Gonna have to cut a hole for the shifter too, for some reason I thought there was one there already, but there isn't. Looks like a bracket and some of the tunnel will have to go bye-bye. More weight redux!!
Old Jun 28, 2006 | 04:33 AM
ThirdGenLS1's Avatar
Car: 1991 Camaro
only thing i had to do with my pedals, is modify where the master attaches to the clutch pedel, jus took the master and clutch pedal to a machine shop and they made it work for like 20 bucks.
Justin
Old Jun 28, 2006 | 02:12 PM
i think the hawks longtubes are a good piece, but the spohn lsx crossmember doesnt work for crap with it. I used the street performance mid lengths on my swap instead of the hawks and after seeing the issues with fuel, exhaust and o2's that red92rs is having i am glad i went with the ones i chose
Old Jun 28, 2006 | 10:10 PM
demetri's Avatar
wow dude......amazing
Old Jun 28, 2006 | 10:12 PM
Car: 1991 Camaro
i'm using the spohn crossmember, and hawks headers with no problems what so ever.
Old Jun 28, 2006 | 10:53 PM
StevenK's Avatar
Car: 91 Z28
Got some pics of how your exhaust is routed?
a little update: I moved the car under its own power for the first time in a looong time, backed it out of the garage and gave it a quick spray down to get the majority of the dust off, then drove it back in. Still need to do the interior, but the list of 'to-do's is definitly getting shorter
Old Jun 28, 2006 | 11:05 PM
Car: 1991 Camaro
i can get one tomorrow if you would like, all i had to do was trim the x-member a tad to get the y-pipe to tuck good, nothing more then a afternoon's day of work.
Old Jun 29, 2006 | 12:01 PM
StevenK's Avatar
Car: 91 Z28
Yes, I'm finding that 'trimming' and 'modifying' is a regular thing in a LS1 swap
Old Jun 29, 2006 | 12:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yea.. thats because everything is ALMOST a bolt-in..
Old Jun 30, 2006 | 12:31 AM
StevenK's Avatar
Car: 91 Z28
Yeah, last thing I had to trim were the mounts for my STB. Its the Edelbrock 3 point, and when I put my ASCD SS Hood back on, the darn thing wouldnt close, so after looking at it, I found the center bar thats above the intake was too high, so I had to drill lower holes so the entire thing would sit lower. It didnt take that long, but its time I would have rather spent on finishing up the wiring and starting the interior work.
Man, I WANT TO DRIVE MY CAR, lol
Old Jun 30, 2006 | 04:11 AM
Car: 1991 Camaro
man that sux i had the same problem, the bmr stb fits perfect under the SS hood. Oh and i never got a chance to snap a pick of the exhuast under the car today, but i promise i'll get it tomorrow
Justin
Old Jul 1, 2006 | 12:20 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
**** Steven.... "The grin of an Ls1 Camaro guy" ....
That had better be me this Friday or its gonna be ugly
Well done man
Old Jul 4, 2006 | 11:46 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I'd like to check it out but it's telling me I'm blocked??
Old Jul 4, 2006 | 10:29 PM
StevenK's Avatar
Car: 91 Z28
Is it a Nuke Sentinel block error?
If so, PM me your IP address and I'll take care of it, most likely someone with your IP before you got it did something to make my site block the IP, this happens alot with bad search engines and spam gathering bots.
edit: I just found one IP banned in the last couple of weeks so I'll assume its yours. I've added the IP to the protected area so you should be able to see anything on ATGO without a problem, if not send me a PM with your IP. Seems you were blocked after seeing my signature here...weird
Old Jul 12, 2006 | 02:14 PM
urslo's Avatar
Car: 1992 Camaro Z-28
Engine: 5.0L
Transmission: 5 Speed
Hey StevenK,
Congrats on the swap!! When you your ready do you want to come down to San Antonio and help me with mine?
Old Jul 13, 2006 | 12:57 AM
StevenK's Avatar
Car: 91 Z28
Originally Posted by urslo
Hey StevenK,
Ummmmmmmmmmmmm
No ;-)
LS1 swaps are a lot of work, I dont know if I want to do it all again, lol.
That said, if you do the swap, take your time, do your research, and BAG AND LABEL YOUR BOLTS/NUTs/SCREWs. Thats whats killing me the most.
Old Jul 13, 2006 | 12:59 AM
Car: 1991 Camaro
well its one of those swaps where now after doing it i could do it in a 1/4 of the time if i were to do it again.
Old Jul 13, 2006 | 08:38 AM
urslo's Avatar
Engine: 5.0L
Yeah I know it is a lot of work. It is just TOOO much work for me to try to do on my own. I don't know anybody here who has done it and that is willing to help. So I will just suck it up and pay the money to have it done at the shop. Thanks anyway!!
Old Jul 13, 2006 | 09:05 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
stevenk:
GREAT call on the moving of the master cyl up.... its SOOOO obvious now, but ive driven my car for over a year without thinking about it. works better.
on a side note, i did notice a hairline stress crack forming between one of the bolt holes and the center hole... its flexing.. im probly going to have to pull the whole pedal and booster assembly out and re-enforce the area... might as well re-enforce the booster area too, since that firewall area flexs from the factory...
Old Jul 13, 2006 | 01:13 PM
StevenK's Avatar
Car: 91 Z28
How bad is the stress crack? you might be able to use a large washer to even out the pressure. I have a freind BigBabyLou that had that happen, but worse, the Master pushed right through the firewall when he pushed the clutch in one day going home from a cruise. I'm not sure how he fixxed it, but if you want I can ask him.
Right now I just need to get the interior in it, button up a few things and check the front end alignment/bump steer (long story) and it'll be ready for a little cruise down the street....I'm sure there will be video of that too
Old Jul 13, 2006 | 01:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i put a HUGE thick washer in there, with a medium size washer on top.. so it should spread out the load just fine now... but i still want a stronger, more elegant solution....
Old Jul 19, 2006 | 08:06 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
StevenK & ThirdGenLS1... how about a picture of each of your exhaust routings by the transmission?
Old Jul 19, 2006 | 09:26 PM
  #42
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
congrats man, sounds good. i need to get a motor for my swap already. cool thing is i have an adjustable master with my t56. u have the spohn t/a setup too what did they change on it?
Old Jul 19, 2006 | 10:07 PM
  #43
StevenK's Avatar
Car: 91 Z28
Most of my pics I have online are Here
Those are really the only pics I have of the headers, and obviously I dont have the full exhaust yet, so I cant really provide much help past that.
Ummm, $400 bucks, got it from Hawks
If your going to run long tubes, you might want to consider the other setup that has recently become available. Its a trans x-member with humps in it that allow you to run true duel exhaust right next to the trans instead of having to go around the huge a$$ Spohn mount like I'm gonna have to do. Then you would need to get a seperate torque arm that mounts to the tail of the tranny of the floorboard. The spohn setup is pretty nice, but damn it kills ground clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
Vintageracer
Jan 10, 2020 05:33 PM
reiderz iroc
Aug 13, 2015 04:57 PM
z28addict8490
Aug 7, 2015 08:48 PM
