LT1 PS line and PS sensor question
Old Jul 15, 2006 | 12:42 AM
Firebat's Avatar
You don't use the PS sensor/switch thats on the high pressure line like you do on some of the thirdgens, right? I'm using caprice LT1 lines and there is a "T" in it and i had the switch connected there instead of leaving the bolt there. The PS whines.
Old Jul 15, 2006 | 12:44 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I deleted the switch and it works fine. do u have enough fluid in the resevor?
Old Jul 15, 2006 | 12:45 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I have no sensor. If it whines it is either low, needs bled or the pump is going bad.
Apparently we are the only ones online right now.
Old Jul 15, 2006 | 12:46 AM
Firebat's Avatar
I filled fluid to the top and it was better. I'm going to try "bleeding" the ps line and making sure all the hoses and connections are tight. Then deleting that switch once I find a replacement bolt.
Old Jul 15, 2006 | 12:48 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I believe it is a metric plug.
Old Jul 15, 2006 | 12:53 AM
Firebat's Avatar
My local hardware store (ACE) should have the bolt. And if its too long i'll cut it, then rethread it. And remember to put on the o-ring also, I remember there being one.
Old Jul 15, 2006 | 07:12 PM
ssean92's Avatar
Car: sold
my line came with the plug
Old Jul 15, 2006 | 10:18 PM
Firebat's Avatar
well, i used to have the plug...
Old Jul 16, 2006 | 11:45 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
how much modding did you have to make to the caprice lines to work if any??
Old Jul 16, 2006 | 11:49 PM
Firebat's Avatar
A little bending by hand, with the lines out of the engine bay, then puting the lines back in to test to fit, repeat. I have heard impala LT1 lines fit with no problems but dont know for sure. I recommend getting 95 caprice or impala LT1 lines, probably from a 1995 car. O'reileys should have the caprice line for around $35. Its the high pressure line you need. For the return line, you just get a few feet powersteering hose.
Old Jul 16, 2006 | 11:59 PM
Firebat's Avatar
I found out that plug i'm missing uses a 3/8" fine thread.
Old Jul 18, 2006 | 04:48 PM
Firebat's Avatar
An upgrade LT1 Powersteering Pump I came across from Turn One. I might consider it if my pump goes out, seems to be running ok though now. The price is kind of high though.
F-Body Power Steering Pump Upgrade
Old Sep 3, 2006 | 06:39 PM
z28colt's Avatar
Car: '92 RS
Engine: Working on LT1 Install
Transmission: Working on T56 Install
I was able to use LT1 Caprice lines with no bending. The only thing I don't like about my setup is that the PS line runs through the S-belt, so if I want to replace my belt, I have to unhook one of my PS lines, then bleed the system. I figure I shouldn't need to change my S-belt too often though.
Old Nov 22, 2006 | 11:31 PM
eagle_eyes's Avatar
Engine: '93 LT1
for some reason the '95 caprice line didn't fit on my P/S pump??? the line has too small of fitting to attach....or am i completely missing something here??
Old Nov 23, 2006 | 12:46 AM
Firebat's Avatar
did you have the rubber o-ring on?
Old Nov 23, 2006 | 02:07 PM
eagle_eyes's Avatar
Engine: '93 LT1
yes, but the threads aren't even catching. the fitting is able to go all the way in passed the head of the fitting. the only thing i can think of is that oreillys gave me the wrong one??? i'll have to check on that tomorrow.
but the return line form the steering box, you just used p/s hose...did you take the stock fitting off the line to attach the hose or what?
Old Nov 23, 2006 | 04:31 PM
Firebat's Avatar
did you try screwing on the hose with the power steering pump out of the car? You might have to bend the line, if the line is not dead-on (or straight-on) with the ps pump it probably won't screw on.
For the return line - I used power steering hose and hose clamps.
Old Nov 23, 2006 | 06:05 PM
z28colt's Avatar
Car: '92 RS
I bought the return line from the LT1 Caprice as well, its pretty cheap and the screw on connection seems pretty secure.
For the reservior line, you need a 3/8" power steering hose. None of the normal auto parts stores carry this, so you will need to call some hydraulics shops or truck parts stores. Do not attempt to use radiator hose, as it will eventually fall apart and ruin you ps pump.
Old Nov 23, 2006 | 08:01 PM
Firebat's Avatar
Or for the reservoir-to-pump line, if you dont already have one, could order one from gm...
Old Nov 24, 2006 | 12:09 AM
eagle_eyes's Avatar
Engine: '93 LT1
yeah, i have it out right now. i can push the fitting from the line into the pump without having to turn the fitting....there is no way this fits. that's why i think it has to be the wrong thing. unless the '93 LT1's have a different pump??
Old Nov 25, 2006 | 07:22 PM
eagle_eyes's Avatar
Engine: '93 LT1
i figured it out. there is a fitting that goes between the pump and the line. this fitting came out when i removed the stock line. i had to dig around a bit to find the stock line, but i got it. also, the '95 caprice lines need minor bending...at least the way i ran them they did.
thanks.
Old Aug 5, 2009 | 07:24 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: LT1 PS line and PS sensor question
thanks.
Minor bending? Look at the bends on the left side of this line. You have to completely straighten out the line, and get the fitting to point the opposite direction. All without kinking the line.
That is an impala SS pressure line. The Caprice LT1 , Baby LT1 and Impala SS line are the same (wouldn't make sense for them to be different. Essentially the same motor between the 4.3 and the 5.7 as far as accessory brackets are concerned.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
