LS1 third gen Exhaust
Old Jul 18, 2006 | 01:15 AM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
Can anyone point me in the right direction? I wanna put headers on my LS1 that is going into my 87 Trans Am. The HAwks Long tubes seem like to much trouble for the price and Long tubes might not be the way to go if I lower the car. Will regular headers fit in a third gen? Like slp (ls1) or anyone else?
Old Jul 18, 2006 | 09:40 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No, the Hawk's swap headers are the only ones available currently. Unless you have a custom set fabbed up.
Old Jul 18, 2006 | 11:04 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Might run your question by JTmiller92. He has an LS powered third gen.
Old Jul 18, 2006 | 11:52 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Phoenix... There is a thread near this one with a pretty detailed desc. of the stainless works (hawks) headers. However...one thing I DO like is the ground clearence. I have plenty. In fact...I think the collectors may sit above the lowest point on the trans crossmember. So dont let ground clearence scare you away. Not sure how low things will be once I get the y-pipe on though...
Justin
Old Jul 18, 2006 | 01:02 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
The clearence issues with LT headers are more caused by the Y-pipe and Cats, not the actual headers.
And seriously, how many of these threads are going to be started. As its been stated many many times, the only header choice that has been confirmed is the Hawks (Stainless Works) LT Headers.
I just saw in another thread that someone has found some mid-length, those are more likely to fit because they dont go low enough down to hit the frame rails like most LS1 headers do on our cars.
But for the price of Mids, the performance gain is kinda iffy, and you might as well stick with a 01+ Manifold.
Old Jul 18, 2006 | 01:19 PM
dingle's Avatar
Car: '83 Camaro
The user here Drews makes (maybe modifies) the tranny X-member so it will accomodate for the y-pipe and cats. Check out this thread.
https://www.thirdgen.org/forums/exha...ml#post2618106
Dingle
Old Jul 18, 2006 | 01:23 PM
Car: 86 Trans AM
THATS what i want to do. Unfortunetly...I have the spohn torque arm that mounts to his crossmember. Its a great piece...and Im keeping it. But it doesnt look like it allows you to use a crossmember like drews...or even to modify the spohn unit to make it like drews. I was going to do a custom torque arm mount and I still might. But as of right now it doesnt look like I can. Anyone have any experience with modifying their crossmember while using that type of spohn set up???
Justin
BTW: Phoenix... I just realized after looking at the post its going into a hijack situation. I apologize. You might still find some of this info helpfull since, as stevenk stated, you are pretty much stuck with Hawks if you want LTs. It would be cool if MrDude comes up wtih a way to easily modify another set of headers to work too!
Old Jul 18, 2006 | 01:32 PM
Car: 1987 Trans Am
Axle/Gears: 4.10's
I am sorry about starting another ls1 third gen thread. I am not going to run cats so will that help alot in ground clearence?
Old Jul 18, 2006 | 02:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the problem is getting the exhaust out of the "frame rails"..
you have thoes two "frame rails" on each side of the trans tunnel... the exhaust has to come out of there...
the clearance issues comes from most people having it come out under the rails or under the trans crossmember... unless you can keep the pipe partway tucked up in there, its going to be low.
so you can either make a crossmember with room, cut and mod the cars rails... or have a exhaust that cuts under it and hangs low there.
Old Jul 18, 2006 | 02:49 PM
bygblok's Avatar
I have heard but not seen a set of third gen headers with the LS flanges on them after some minor moving of the tubes. Seems like I was told that two tubes are close and the others are waay off but it can be done with a little fab knowldge. My question would be if I went with a shorty conventional header, how much angle change is there at the flange as far as the exhaust port height and direction. I can get the flanges from Pace Performance but not sure if I want to try and hog up a set of headers just to suit my cheap ***!! Just can't justify a set of headers like that when I need more parts that are far more important.
Old Jul 18, 2006 | 03:34 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you want shortys, either get 4thgen shortys, or keep the manifolds...... id just keep the manifolds, since you wont see a gain from the shorties.
we're talking about actual performance headers.. so they MUST be longtubes... you dont see a gain with shorties because the factory manifolds are that good...i put over 366hp to the ground with the exhaust manifolds...
Old Jul 18, 2006 | 06:31 PM
bygblok's Avatar
yea, I know the shorties suck for performance gains but the manifolds are just so damned ugly!!! So the 4th gen shorts will work still? Hmmm, might not have to change a bunch of exhaust if I go that route until those header prices come down some!!
Old Jul 18, 2006 | 08:23 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I ended up using the Hawks Headers and Y-pipe but modded the y-pipe in several places. Still not happy with the fit amd plan on c-notching my frame so that i can tuck it up more.
Old Jul 19, 2006 | 03:06 AM
deracer's Avatar
Car: 91 Z28
Transmission: TKO 600
You could always try to make your own exhaust. We're just finishing up on mine. Nothing special, exhaust manifolds, 2 high flow cats from ebay with a hooker aerochamber. It runs above the crossmember. Here is a pic of it so far, its all in just tacked. Best pic I can find as of right now...
Old Jul 19, 2006 | 08:12 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Great minds think alike. That's what I was thinking of doing, that way I would have as much ground clearance as possible. I take it you used the same size pipe from the manifolds (2.25") to the Y (where did you buy that?) and then a 3" out the back?
Old Jul 19, 2006 | 09:18 PM
deracer's Avatar
Car: 91 Z28
I think it was flowmaster, but I'll have to check. We had to cut the intakes off and weld them to the pipes then weld it back to the collector. It's a pretty impressive piece. There is so much ground clearance on this setup, it stays above the torque arm al lthe way back too. Hopefully it al lworks out and I'll be driving by sunday. Will let you know how it turns out....Let me know if anyone is interested in any pics.
EDIT: here is a link to it, I think it's the same one. Motorsport Technologies, Inc. -:- LS1 F-Body Exhaust Upgrades
Old Jul 19, 2006 | 10:11 PM
StevenK's Avatar
Car: 91 Z28
I need more pics of this, various angles. Looking at this pic, and looking at pics of my car with headers only, I see no way of getting the exhaust like that.
Old Jul 19, 2006 | 10:28 PM
deracer's Avatar
Car: 91 Z28
Well I'm using a tko transmission instead of a t56. It leaves a lot more room. I have yet to see how a t56 fits in these cars, but I'm guessing it makes it a little harder. Tomorrow, we're going to finish welding it all together and probably paint it. Friday it's going back on. I'll try to grab as many pics for you as I can.
Old Jul 20, 2006 | 06:24 PM
THIRD GEN 92's Avatar
Car: 92 Camaro Rs Ls1 converted
Engine: Ls1 346
Transmission: t56
Axle/Gears: Moser/4:10's
thats almost the same setup im using in my car also except i have a th350. A 3'' y pipe runs though the spohn trans x member and then connects with a 3'' Y connector.
Old Jul 20, 2006 | 08:26 PM
super_kev's Avatar
Car: '85 TA
Don't use Putfile; images disappear after time, and (in this case) you can't hotlink them. Just add them as an attachment, or send it to me so I can shrink it for you.
Old Jul 21, 2006 | 08:42 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
his transmission is physically smaller.. you cant route it that way with a T56....
Old Jul 24, 2006 | 02:36 AM
deracer's Avatar
Car: 91 Z28
Well wanted to give you guys an idea anyway. Here is a link to some picutes of the exhaust before paint:
Index of /cars/camaro/exhaust
Old Jul 24, 2006 | 07:29 AM
Car: 86 Trans AM
Thats a nice looking piece!! Wish there was room on mine to do that...but I just dont see it happening. I do have a quick question for you though. What are you using for the connections of the pipes? The flanges I mean? Are those things welded onto the pipes themselves? Then a regular gasket goes between them? Ive used the ones before that come with the short little piece of pipe...but the flange part is loose on them until bolted up. THis idea looks better and there is no way for the pipes to move or settle once bolted up. Where did you get em from? Thanks!
Justin
Old Jul 25, 2006 | 11:16 AM
deracer's Avatar
Car: 91 Z28
They are all hooker header flanges. The ones that bolt to the exhaust manifolds are custom made 2.5" flanges with 3" bolt pattern.
Old Aug 8, 2006 | 04:29 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Hawks SW LT's all the way... then use the "drews" xmember and to get the pipes thru the x-member and tucked up high just use the hedman headers "s-bends"... mandrel bends and they work perfect... just a little cutting/welding to get it all lined up and tucked. Then you can do a y-pipe or x-pipe after that.
Old Aug 11, 2006 | 02:05 PM
deracer's Avatar
Car: 91 Z28
Is this what you use? If so do you have any pics?
Old Aug 14, 2006 | 02:00 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Subscribing. Will this setup work/clear with 4L60E?
Old Aug 14, 2006 | 06:46 PM
Burn's Avatar
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
Now for the BIG question. Will the 3inch collector option work like this too or am I just asking for trouble?
Old Aug 14, 2006 | 06:51 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
3" collector option? What?
Old Aug 14, 2006 | 09:05 PM
Burn's Avatar
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
Take a look at the page were Hawks sells the LTs and they have a new upgrade option for $50 plus a 4 week wait to get 3 inch collectors. They come with 2.5 if I remember correctly.
Old Aug 14, 2006 | 10:17 PM
Engine: Ls1 346
Transmission: t56
I bought mine with a 3'' inch collectors but it rubs on the passanger side rail which I got fixed.
Old Aug 15, 2006 | 09:34 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Yeah, I saw that on their site... I've always considered cutting my 2.5" collectors off and having a friend TIG some 3" stainless ones on.Not really worth it to me right now... guess I'll find out on my new motor. Should be 525RWHP or more NA.
Old Aug 22, 2006 | 01:12 PM
KhaotikRaje's Avatar
I emailed Hawk's last night about what the wait time would be for a set of his LS1 conversion headers with no AIR fittings and 3" collectors. He responded to me 2 hours later saying that he had them in stock, and would ship within 24 hours of my payment. With that said, I bought them right on the spot. I will probably be getting them this week or early next week. I was kind of worried that I wouldn't see them for 4-6 weeks from now, and that it would hold up my project. I'm quite impressed with the service from Hawk's!
Old Sep 10, 2006 | 03:25 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
for anyone interested in a used set of hawks lt's and y-pipe, I am selling mine
Old Sep 10, 2006 | 05:53 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I'm interested....how much are you looking to get for them?
Old Oct 10, 2006 | 11:05 AM
kylebowditch's Avatar
Car: 91 Firebird
Transmission: auto
heddman is suppossed to be coming out with a shortie header for a ls1 into 3rd gen swap early '07, but they reccomend/require you to use trans dapt motor mounts
heddman # 62800
transdapt # 4592
Old Oct 10, 2006 | 01:36 PM
Car: 86 Trans AM
I was going to get the 3" collectors, but I didnt really see a need to. Even with all my mods the 2.5" collector and y-pipe will flow good enough for now. Like mentioned above...later on I might add the 3" collector to the headers and make a new ypipe.
Justin
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
