Anyone else using a 4l60e(M30) have a long vacuum hose coming from it?
Old Apr 13, 2007 | 02:51 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
When I got my 4l60e(M30) it had a long vacuum hose coming from the top of it. I'm just wondering did anybody else using the 4l60e have the same long hose. If so what did you do with it? Did you leave it hanging or connect it to something?
Thanks,
Jay
Old Apr 13, 2007 | 02:59 AM
rgauder's Avatar
Car: 1987 Trans Am
Re: Anyone else using a 4l60e(M30) have a long vacuum hose coming from it?
I'm not positive on this tranny, but a lot of automatics have a vent tube coming out of the top of the trans casing.
Old Apr 14, 2007 | 01:53 AM
Car: 1991 Z28 Vert
Engine: LT1 350
I basically just need to know should I connect it to one of the ports on the intake or not?
Thanks,
Jay
Old Apr 19, 2007 | 07:56 PM
Firebat's Avatar
It doesn't connect to anything
Old Apr 19, 2007 | 08:17 PM
Car: 1991 Z28 Vert
Engine: LT1 350
Firebat,
Are you certain it does not connect to anything because them is a very long vacuum hose?
I guess it just seems like to should connect to something because of the length.
Thanks,
Jay
Old Apr 19, 2007 | 09:02 PM
Firebat's Avatar
I'm pretty sure but how long is it? I've helped my brother swap 4l60e trannys on his 95 t/a at least 2 times and never hooked that line to anything.
Old Apr 19, 2007 | 09:27 PM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
Is that not line for overflow of tranny fluid?
Old Apr 20, 2007 | 01:41 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Firebat,
I would say that the hose is at least 4ft.
Camaro_SS,
I'm not sure what you mean by that. I have never heard of such.
Jay
Old Apr 20, 2007 | 06:29 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I am 90% sure it is a vent line, I believe it is located on the top above the front pump area. Most automatics have the same thing, usually it is just a small tube about 2 in long about the same place, if the trans seriously overheats it uses that instead of blowing input or output shaft seals. The 4l60E is all electronic controlled, the only hook up besides the shift linkage is wire connections as I recall. Sounds like someone just put a hose on it so if it did vent it wouldn't undercoat the floorpan.
Ask Pro Built Automatics on this forum, should get a 100% positive answer
Old Apr 20, 2007 | 04:10 PM
Pro Built Automatics's Avatar
I have seen the vent hose that is over a foot in length, on cars, but I have seen them that long on 4WD vehicles before. It comes up the back of the firewall and loops over to prevent water from entering when they do some serious off roading. If it is in the way, shorten it.
Old Apr 20, 2007 | 09:24 PM
Car: 1991 Z28 Vert
Engine: LT1 350
Thanks for the info.
I will just cut it down some.
Jay
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
