Another LT-1 Swap: DONE!
Old Aug 26, 2007 | 02:54 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
Well I actually swapped it couple months ago, just kinda tossed it in actually. This time around I went for the gusto. Complete rebuild, LT4 HOT cam w/ 1.6 Roller Rockers, Headman Shorties, a little dress up, and lots of paint. Now I just need a new car to wrap around the sexy engine!
Check out more pics HERE
Old Aug 29, 2007 | 01:06 AM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
Re: Another LT-1 Swap: DONE!
it looks great Do you have any more pics?
Old Aug 30, 2007 | 08:26 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
very nice. im lookin to do one of these projects myself soon. do u have the stock bottom end in it?
Old Aug 30, 2007 | 08:33 PM
JDud's Avatar
Looks good, have you put the accessories back on the front of the enginge? Just wondering if the alternator fit with those valve covers...I finally painted the factory LT1 covers and put them on.
Enjoy the new power plant!
Old Aug 31, 2007 | 12:29 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Yea the bottom is bone stock. Upgrades are:
LT4 HOT Cam
1.6 GMPP roller rockers
Headman 1 5/8 prim shorties
ZOOM stage 2 Kevlar Clutch
Tremec 3550 w/ Steeda short-throw
I did get the bracket back on. Had to order a new one seeing as one of the tabs broke off. Anyway. The alternator will clear those with a little bit of grinding with a dremel. there is a small "ear" sticking off the upper part of the casing that has a bolt in it. just grind that down almost flush with the lower part and it slides right on.
I also added over the valve cover wires yesterday. They are pretty sexy :-D.
I will add some more pics after I get it back from the exhaust shop.
Old Aug 31, 2007 | 03:08 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
nice, wouldn't mind FI someday...i bet those LT1's just keep getting cheaper and cheaper with the lsx's out now huh?
Old Aug 31, 2007 | 03:18 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Mine was actually from a 94 Formula I owned. Had a string of bad luck with and ended up having to leave it, basicly in a corn field for 1.5 years. So I gutted that car and put it all in my 3rd gen. Seats, dash, engine, rear end, heck even the muffler :-p. I had a complete donor when I did my swap.
Old Aug 31, 2007 | 03:28 AM
Tobias05's Avatar
thats the way to do it. think im' gonna buy my mothers 86z28. 72k on the odo, pristene condition. would be perfect for a lt1 swap.
congrats on your hard work, i know what its like swapping engines.
Old Aug 31, 2007 | 05:22 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Thanks for all the praise on my project. It really was a lot of work and fun as heck. I must also say thanks to all on tgo.org for the help, and shbox.com is probably to best place around to get any lt-1 info you might need.
Old Jan 7, 2009 | 04:04 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
What computer did you use to go with the Tremec 3550? The standard LT1 M6 computer?
Old Jan 7, 2009 | 11:40 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
I used the standard a4 ecu and just disabled the auto tranny control with tunercat. quick and easy. I think the M6 one would work ok but you might have to disable to some safety features like neutral lock out and things.
Old Jan 10, 2009 | 01:54 PM
Choppycam's Avatar
Car: Iroc-Z 1985
Engine: LT1 1995
Axle/Gears: 10 bolts, 3.42 with Posi Auburn
Hi ! Do you have any pictures of the gap between your headers and the brake's line on driver side? You don't need something on your header to improved the high temperature beside the brake line? So, its some questions that I have about this swap. I performing the same swap actually. thanks
Old Jan 10, 2009 | 02:55 PM
ssean92's Avatar
Car: sold
What did you do for the Alt.....
Old Jan 13, 2009 | 12:11 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Lets see brake line should probably be wrapped but I didn't. I just bent them out of the way.
As for the Alternator what do you mean? The wiring? I went and purchased a new connector from napa for it. The replacement ones have all 3 wires. I just used the field and excite connections.
If you mean the taller valve cover. Just grind down the back of the alt. took all of 5sec with an angle grinder.
Or maybe you mean cause there isn't one in the pic? Yea I hadn't installed the accessory bracket when I took that pic. just engine in place for show lol.
Old Jan 13, 2009 | 12:34 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
how did you do your fuel system and wiring?
buddy of mine wants to swap his 95 trans am drivetrain into his 84 trans am
Old Jan 13, 2009 | 03:35 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
wiring is more than I could ever cover seeing that all the years of third gens and even the firebird to camaro are different. I used a lot of shoebox's website for the 4th gen stuff and then just searched the web for type specific wiring for the third gen. So far I've had this set up in an 86 and 92 Camaro one was TPI the other was TBI. Right now it is in an 89 Trans Am. All three were different.
The fuel pump will very depending on the year but i recommend just getting a walbro 255lph pump and call it good. For connecting the lines I just purchased fuel injector fuel line and used fuel injector clamps. cut the steel lines with an angle grinder and put them together. Some say it's a bad idea but I've been runnign this setup for about a year and half with no problems.
Old Jan 20, 2009 | 05:19 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
nice going , but I think all that red is just a bit tacky looking.
Old Aug 18, 2009 | 12:15 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Does the 3rd gen clutch, slave cylinder, throwout bearing, etc. work w/ the Tremec 3550?
Old Aug 18, 2009 | 07:54 PM
5-0 Blackbird's Avatar
Car: 87 Firebird Formula, 97' GMC Sierra
Engine: LT1, 4.3 Vortec
Transmission: T-56, 4L60E
Axle/Gears: 4.10 Posi, 3.42 Posi
Looks nice man. I'm trying to collect parts to get my swap rolling. Only got an engine and a T-56 so far. Hows the setup now? Are ya satisfied with the swap/ performance? So where are the video clips? lol. You should post up some pics of the final setup.
Old Aug 18, 2009 | 09:23 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
That engine actually broke number 1 rod in half. Got a crack in the cylinder wall and... well the rest is history. As for performance it was nice. But I built a new motor and put it into a trans am... it was nicer. Went with a CC306 LE1 ported heads and few other addons.
Everything for the transmission is a direct swap with the exception of an adapter plate to mount the tranny to the t5 bellhousing and the crossmember. everything else is out of a third gen.
Old Aug 18, 2009 | 11:25 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Do you remember where you purchased the adapter plates or is this something you fabricated?
Old Aug 20, 2009 | 01:12 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
fortesparts.com I got the transmission and the "kit" for the install all from them.
Old Aug 20, 2009 | 10:58 PM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
Congrats on the swap. They sure are fun once you get to drive them.
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
cRoe4
Aug 7, 2015 08:46 PM
BlazinOR
Nov 23, 2001 08:32 PM
elevario
Jun 16, 2001 11:37 AM
