LT1 swap Air intake
Old Apr 22, 2008 | 08:22 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
LT1 swap Air intake
I swapped a 97 LT1 into my 89 Camaro. Everything runs fine but I am currently using the factory style TPI intake set up, which looks nice but I think it may be too restrictive. I tried to do a search for this but I cant find too much on what I am looking for. I am curious to see what others used for their intake. I was contemplating using an LT1 elbow with a cone filter but if I am not going to see any gains out of it then I may just leave it alone. Please post pictures of your set up if possible, and constructive opinions.
Old Apr 22, 2008 | 06:32 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 swap Air intake
The elbow an filter would be less restrictive than what you have now. Most have to make there own. I seen a pic on here where one guy used exhaust pipe and the rhyno liner on the pipe and it looked really good.
Old Apr 22, 2008 | 07:25 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
that may of been me, used a 4inch k&n and then a 4inch mandrel bent 90 degree piece from jegs I believe.
https://www.thirdgen.org/forums/post...33-post17.html
Old Dec 20, 2011 | 01:12 PM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
whoa i know this is a old post but i am going through the same dilemma. i cant find nothing that will work. i too have a LT1 from a 96 vette, do i need the elbow going towards the passenger side? pleas help thanks.
Old Dec 20, 2011 | 02:26 PM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Don't bother spending money on an expensive elbow. Check eBay for aluminum piping and build a kit on your own. Hose couplers are dirt cheap, piping is also. Just make sure you leave a provision for the sensors.
Old Dec 20, 2011 | 08:44 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I don't regret buying my Trickflow Elbow. I got the Ceramic version and its a very good piece. Ebay elbow looks cheap to me.
Old Dec 21, 2011 | 02:50 AM
Car: 1991 camaro RS
Transmission: 700
well so far i fond a elbow that i think will work and that will meet the clearance. what do you guys think?
http://www.jegs.com/i/Vortech/933/4GH112-050/10002/-1
Old Dec 21, 2011 | 04:30 AM
Carlos773's Avatar
Get the trickflow Elbow. Its cheaper and comes in 3 versions. Plain, black and ceramic. Get the plain one.
You can flip it around just fine for your application.
Old Dec 21, 2011 | 02:32 PM
Car: 1991 camaro RS
Transmission: 700
looks nice carlos!! here is the thing that worry's me, if i flip it around will that not touch the battery? and since i have a LT from a vette all of the ACC are on the left side so idk if it will be touching pulleys or belts you know. what if i just go with the elbow going straight to the filter? will that work? thanks!!
Old Dec 21, 2011 | 03:30 PM
Zantasmo's Avatar
Car: '87 Iroc-Z, '91 Trans Am Vert
Engine: 5.7 LS1, 5.3 LS
Transmission: T56, T56
Axle/Gears: 4.11, 3.27
If you have the TPI intake setup from Camaro, you can keep it. It didn't restrict anything with my LS1. And it was putting 320hp to the wheels in the dyno.
Old Dec 22, 2011 | 02:45 AM
Car: 1991 camaro RS
Transmission: 700
i had a 305 so no i dont have the TPI intake pluse it has no room for me to use my MAF. think ill go with the trickflow elbow and hope it fits with out touching anything. thanks though
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
