my lq4 swap
Old Jun 11, 2008 | 09:19 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
my lq4 swap
ok ive been working on my car for about three years now. i have completely rebuilt the rear end, with '96 rear discs, re-wired entire car, installed all auto meter guages, and finishing up with a lq4 motor with ported heads, dual exhaust, carb swap, and th350 race trans. i will be posting more pics soon, but here is a few to start.
Attached Thumbnails my lq4 swap-motor-2.jpg   my lq4 swap-my-motor.jpg   my lq4 swap-trans-oil-pan.jpg
Old Jun 12, 2008 | 07:34 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: my lq4 swap
looking good . keep us posted with pics. and explain problem areas . good luck .
Old Jun 13, 2008 | 01:33 PM
bowtienick's Avatar
Re: my lq4 swap
ok some more pics. one problem with this swap is the accessories. well,since this is going to be mostly a track car, i am only running a water pump and alt.
i used the stock lq4 water pump, hoses for a 4.8/5.3/6.0 silverado, with the lower hose sectioned with the stock camaro hose. the upper hose is sectioned only to install a cap, scince it is now higher than the radiator cap.
i then made brackets to use the stock 1991 camaro alternator, which the stock pulley matches the others. anyway, heres some pics
Old Jun 13, 2008 | 01:37 PM
bowtienick's Avatar
Re: my lq4 swap
here is a couple of my guages
Old Jun 13, 2008 | 01:46 PM
bowtienick's Avatar
Re: my lq4 swap
one little snag i hit when installing is obviosly the deep truck oil pan. i bought a moroso oil pan, which is the steel version. there are two verisons out now, but if you get the first version, the truck windage tray, which is full length, fits. i only had to cut a little clearance around the pickup mount for the new pickup. i know the new version is shallower to work with 4th gen f-cars, but the older version fits our cars just fine
Old Jun 13, 2008 | 02:31 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: my lq4 swap
Work looks pretty good! I wouldnt mind some more pics/specs on that exhaust you have going there.
J.
Old Jun 14, 2008 | 10:59 AM
bowtienick's Avatar
Re: my lq4 swap
the exhaust idea came to me from combining two systems on this site. basically i used two generic over the axle tailpipes to go around the spohn crossmember, into an x , dual pipes and a dual in, dual out muffler on the pass. side. if i would have paid a bit more attention, i think i could get a bigger muffler in there. the lowest point is where it crosses form the driver side, due to the sfc and crossmember both being in the way. it gues up via 45 angles to the stock f body manifolds. took about one weekend and a couple of days afer work to tack/cut/fit .
Attached Thumbnails my lq4 swap-exhaust-2.jpg   my lq4 swap-exhaust-3.jpg   my lq4 swap-exhaust-4.jpg
Old Jun 14, 2008 | 11:05 AM
bowtienick's Avatar
Re: my lq4 swap
here is a couple more
Old Jun 15, 2008 | 04:42 PM
bowtienick's Avatar
Re: my lq4 swap
ok, here is some more pics. these are some mor on the alt. brackets, and how i routed the belt, and a shot of how i did my fuel cell and battery box. i have to get a sheetmetal box fabbed up to cover the cell, and ive got to finish up the interior.
Attached Thumbnails my lq4 swap-alt-bracket.jpg   my lq4 swap-belt-routing.jpg   my lq4 swap-battery-cell.jpg
Old Jun 15, 2008 | 04:55 PM
bowtienick's Avatar
Re: my lq4 swap
pics of shifter, trans cooler, and under car showing fuel system, rear end, torque arm, etc. with the hooker mounts, the motor bolts in exactly where a gen 1 block would. this allowed me to use the spohn torque arm/ crossmember for a th350 swap. the motor came from a truck with a 4l80 trans, so it had the correct spacer and th400 bolt pattern; so all i needed was a converter with the dual th350/400 bolt pattern. i think this was a pretty easy swap, as everything literally bolted together.
Attached Thumbnails my lq4 swap-shifter.jpg   my lq4 swap-trans-cooler.jpg   my lq4 swap-under-car.jpg
Old Oct 28, 2008 | 05:19 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
Re: my lq4 swap
what kind of spark plug wires are those???
Old Oct 28, 2008 | 06:46 PM
UNCLE TOM's Avatar
Re: my lq4 swap
look like blue ones to me . just a joke . check jegs & summit , you can get most any color you want . i like MSD , think they only come in red . i am sure many companies make different colors . good luck .
Old Oct 29, 2008 | 06:26 PM
Engine: lq4
Transmission: th350
Re: my lq4 swap
i dont care about the color... they look beefy thats why i asked... checking jegs now
Old Nov 3, 2008 | 06:05 PM
bowtienick's Avatar
Re: my lq4 swap
the wires are taylor units. theay are 10 mm core dual insulated. i figured when i get headers, im gonna need the extra heat protection. i think they were around $70 when i bought them
Old Nov 3, 2008 | 10:49 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: my lq4 swap
Originally Posted by bowtienick
the exhaust idea came to me from combining two systems on this site. basically i used two generic over the axle tailpipes to go around the Spohn crossmember...
Hmmmm... I might just "borrow" that idea when I do my own exhaust... (It's gotta be easier than the hack/chop/weld thing I was thinking I'd have to do!)
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
